jdog
    2
Everything posted by jdog
  1. So they can use the female end that gets lost in the tool box and you have to then get a new one. Or so that you can put different wrenches on it depending which job you are working on.
  2. its for a distributor wrench or a offset wench
  3. Stovepipe is the name of it, it goes between the exhaust manifold and the air box, it is designed to bring warm air to the air box when it is cold. It can be removed as most of them are torn because of the age, or you can buy a new one.
  4. Don't matter to me
  5. I've got a colorado one if you want
  6. I read somewhere that if you power your amp with the power antenna feed off the radio that it would do the same thing.
  7. Only thing I see is that the rca is on a input not a output but that's about the only thing obvious to me. But I've never installed one before. Maybe switch it to rear output on the radio?
  8. So did I it idled great but as soon as you took off it ran like crap.
  9. How are you indexing the dist? When mine did this I put it all at tdc and it did the same thing, the only way I got it to run right was indexing the dist. per cruisers tips and cutting a window into an old cap.
  10. Looked at it, was going to drive it but it's drizzling and has a possibility of snow, so it sits. Maybe tomorrow will be better.
  11. The other end is blocked, I don't see that happening. Could it be that the key was just so worn the ridges worn down. The other possibility is that when you pulled the old one out they came out and are on the floor. I would like to see the old key, can you send me a picture of it?
  12. Sounds like the throw out bearing if it goes away with the clutch in.
  13. Not a problem, I've seen it a few times
  14. Speaker wire grounding out to the window regulator. Bet if you pull the panel you'll see the wires facing the rear of the vehicle. Then when you move the window down the regulator cable moves and touches the speaker.
  15. https://denver.craigslist.org/pts/d/denver-truck-topper/6799576058.html
  16. Didn't even pay attention to the photo, my mistake figures google will give me the broken pictures.
  17. Just tow one of these behind you with cords running from it to the space heaters.
  18. Block heater with a generator on a stand off the trailer hitch?
  19. Nope they are not
  20. If it's what I think it is its to keep the unit from freezing, it senses the temp and cuts the power to the clutch. But I could be wrong been a while since I studied a/c.
  21. any codes?
  22. I got a 89 xj and a 88 mj
  23. same key do it all the time? only reason i ask is Chryslers security system will allow the car to start then immediately die when it does it does the security light stay on, it will either be a solid light or a picture of a key.
  24. Did you use the correct fly wheel when this motor was Installed?
