jdog
    2
Everything posted by jdog
  1. Factory gauge are not accurate measurement for the voltage. When checking the cables make sure to ohm them from end to end. 1988 swb 4.0 ax15 np 231 red with gray interior.
  2. Either starter or bad cables 1988 swb 4.0 ax15 np 231 red with gray interior.
  3. Need ten posts for classifieds. I would eliminate the rear height valve and install a cherokee prop valve. 1988 swb 4.0 ax15 np 231 red with gray interior.
  4. so from what i'm seeing its a gm based system, wonder if a scan tool would tell you any data? the timing sounds correct. I'm still leaning towards a leaking injector might not be a bad leak, can you look in the throttle body and see what the spray patterns like when its at idle? Does this motor have adjustable rockers? I'm not knowledgeable about these older fords, but i know Ford did use them at one time.
  5. Come on out Pete, you can visit a few yards and get some of the good parts, but you better bring a truck.
  6. whats the base timing set at? could it be a leaking injector, would explain why it runs great when in the throttle but when sitting at idle for a while the fuel build up? does this thing have a air fuel ratio or any kind of data?
  7. jdog
    Universal joints
    Usual the driveshaft gets bent when they pick up the vehicle.
  8. Which way are you counting the cylinders for your firing order, Ford is different than gm and Chrysler.
  9. No hard lines here, all rubber but I did grab the brackets
  10. https://denver.craigslist.org/cto/d/castle-rock-1987-jeep-comanche-pickup/6924894796.html
  11. are you still looking, there is a 87 w/ a 2.5 that just came into LKQ in Denver, I can grab items if needed.
  12. Found a bed mat that says jeep on it.
  13. jdog
    1jthl651xht001213
    I can head ba k tomorrow and see what's all there take pics and grab it. Do you need the stalk to?
  14. jdog
    1jthl651xht001213
    Also had ac
  15. jdog
    1jthl651xht001213
    I wish, the way its pictured is the way I seen it. it was a 2.5 with cruise, manual trans and a/c. If anybody wants anything off it I can go back but taillights, emblems interior lights and rear window are gone. Hopefully someone on here got them and not the local ebayer.
  16. jdog
    1jthl651xht001213
    At the local lkq
  17. Still curious about what the condenser looks like and wither its been cleaned
  18. If those check out check your battery cables if youve got a ohm meter disconnect it from the battery and ohm the cables.
  19. Fuse links are near the battery and starter relay if memory serves me correct. But with http://jeep.zerok.ru/index.php?page=196 it shows they come right off the starter relay. I would start there. The thing with fuse links is finding the soft spot and see if you can separate it. FYI just cause it's new doesn't mean it's good, had a co worker buy a brand new battery and still have to use a jump to start his ride.
  20. Battery charged? If so it could be a bad or disconnected ignition switch or fuse link. Do you have headlights?
  21. jdog
    New to forum
    Hello and welcome
  22. my first guess is extra but would like to see what you got, if you could supply a picture it would help
  23. jdog
    1JTML6319JT136948
    Thank you
