I've had a few electrical issues with the '90 eliminator I recently purchased, the relevant ones being that the hazards/brake lights were not working, the headlights couldn't be switched from high to low beams, and my left turn signal dash light would stay light when my running lights were on, but only when I wasn't signalling.
Hazards/brakes turned out to be a fuze issue, and the headlight issue was from the sliding plastic piece that actuates the toggle switch was out of place. When I had my turn signal switch out of the way I notice this part (that I can't seem to identify) that was loose and cracked located right by the locking cylinder. When I inspected it, one of the arms broke off in my hand.
My turn signal dash lights now work properly, but as he title reads my front driver's side blinker doesn't function at all anymore. The bulb isn't burnt, there isn't any corrosion or grease, and I'm not getting any power to the socket. Am I dealing with a bad socket? Did the part that I broke have something to do with it? I'm pretty new to all this as this is my first vehicle so any thoughts or advice are well appreciated.
