jdog
    2
Everything posted by jdog
  1. jdog
    CC cookbook
    I love older cookbooks, will have to try this when the stores start getting stocked again
  2. jdog
    CC cookbook
    I think it's on the same premise as corn flake chicken it sounds like, will have to make this next time I have frosted flakes
  3. that four pin weather pak goes to the a/c harness. whichis the a/c relay low pressure switch and a/c compressor
  4. jdog
    CC cookbook
    What some of your favorite recipes, with this virus I have found myself cooking more as I now have the time, so CC what are your favorite recipes? I'll start: Irish Nachos 1 bag of kettle chips bacon cheese green onion sour cream tomatoes guacamole throw chip on a pan, sprinkle with cheese, cooked bacon and anything else you want on it put in oven at 350 degrees till cheese is melted remove from oven, add remaining ingredients and enjoy
  5. is there one for the a/c relay?
  6. If you have one, which you should have if you got the rebuild kit. Replace it
  7. Thank you Pete
  8. jdog
    1JTML6319JT136948
    *B1-DESCRIPTION NOT AVAILABLE -SA-Charcoal AGC-Black Ram 1500 Sport Group APA-Monotone Paint CBA-Straight Back Bench Seat CGX-RR Head Restraints Outboard Seating CKA-Carpets - Floor and Cargo Area DDQ-5-Speed Manual Transmission ERB-4.0L I6 Engine GAC-Tinted Glass Windows JJA-Cigar Lighter LAP-Shift Indicator Warning Lamp LMA-Halogen Headlamps MDA-Front License Plate Bracket NAF-High Altitude Emissions PE4-Colorado Red QE4-Colorado Red RAC-AM MTR Radio SBA-Power Steering TBG-Compact Spare Tire WMC-Open body style: MJJL61
  9. Looks like it's for a ram. Good job saving it from the crusher
  10. looks like its safe to drive
  11. jdog
    1JTMG66P1JT235705
    being parted out on ebay, https://www.ebay.com/itm/COMANCHE-1988-Radio-Audio-15044829/352859125987?hash=item52280af8e3%3Ag%3ARCoAAOSwA2hd00dT&LH_ItemCondition=4
  12. jdog
    1J7FT26P6NL162140
    build date 11/11/1991 *C1DESCRIPTION NOT AVAILABLE -SA-Charcoal ALAP- CBAP-Straight Back Bench Seat CKAP-Carpets - Floor and Cargo Area DBBC-All Manual Transmissions DDQ5-Speed Manual Transmission EPE-2.5L I4 Power Tech Engine GRZP-Left Remote Mirror GSZP-Right Remote Control Mirror GTZP-Manual Remote Mirrors JHAP-Var Intermittent Windshield Wipers JJAP-Cigar Lighter KERP-DESCRIPTION NOT AVAILABLE MBJP-Black Front Bumper MHAP-Black Windshield Moldings MMKP-Lower Grille Surround-Painted Silver PE4-(Colorado Red) RAAC-All Radio Equipped Vehicles RAFP-AM/FM Cassette Radio RCDP-4 Speakers SBAP-Power Steering SCGP-Leather Wrapped Steering Wheel TMWP-All Terrain Tires TZAP-Goodyear Brand Tires WJNP-15 Aluminum Wheels WLZC-All Aluminum Wheels YGEA-5 Additional Gallons of Gas Z01P-Rear Spring Group IZ56P-Left Front Spring Group Vi Z75P-Right Front Spring Group v2 TCA-Customer Preferred Package 2tc 23-CCustomer Preferred Package 23C 3VNA-Customer Preferred Discount 4EA-Sold Vehicle 4M1-PRetail to Bid Diversion Tracking 4UA- ASCA Tissue North America LLC 4XA-Air Conditioning Bypass APAS-Monotone Paint BAPS-75 Amp Alternator BCCS-Dual 730 Amp Maint Free Batteries BGAS-Power Front Disc/Rear Drum Brakes CUMS-Mini Floor Console DMFS-4.10 Rear Axle Ratio DRJS-175MM Rear Axle GACS-Tinted Glass Windows GBBS-Tinted Windshield Glass GCBS-Front Door Tinted Glass GEHS-Fixed Door Vent Glass HCDS-Do Not Use - See HCA JAZS-DO NOT USE - See JP, KA classes JCAS-85 MPH Primary Speedometer KWRS-STRIPE/BADGE/MOLDING/COLOR K3ZS-STRIPE/BADGE/MOLDING/COLOR LAPS-Shift Indicator Warning Lamp LBCS-Glove Box Lamp LMAS-Halogen Headlamps MB1S-Black Front Bumper MFFS-Black Grille MMCS-Rear Door Solid Window Insert MMGS-Belt Moldings NAAS-Federal Emissions NBKS-EVAP Control System NF2S-18.5 Gallon Fuel Tank QE4S- SFAS-Standard Duty Front Shock Absorbers SGAS-Standard Duty Rear Shock Absorbers TBCS-Compact Spare Tire TBMS-Tire Carrier Winch XBSS-Pickup Box YAAS-Build To U.S. Mkt. Specifications Z1AS-GVW/Payload Rating 1AAS-U.S. Dealer Retail165SZone 65-New Orleans codes have been reused,
  13. while the seats out steam your carpets.
  14. post up in the registry and someone will get one for you
  15. should just have a o-ring at the base, should come out by just pulling it, altho some have a bolt at the base
  16. yeah, youl'll have to remove the perchs and weld them back on under the axle. as for brake lines, it looks like they just removed the bracket and bent the lines
  17. no info, google fu says they are peterson 126c interior lights https://www.rockauto.com/en/parts/peterson+lighting,126C,interior+light,1001472
  18. so on the rear you are spring over, will have to change that back to spring under. The front just looks like springs, sway links, trac bar. and I'm going to assume upper and lower control arms as no side picture
  19. Figured I'd put this in the pub and not in the wanted section. I am looking for dealer window stickers, just need a copys of them. Thank you
  20. very nice, welcome
