Moose
Moose's Achievements
  1. Moose
    EGR Solenoid
    Looking to get an EGR solenoid for a 1990 renix. I'll cover shipping costs, located in Canada.
  2. Rockauto is awesome for canada. No door handles listed unfortunately
  3. Thanks for checking. I live in Canada though and after a quick search it's seems to be around 50$ per handle up here
  4. Decided to try to drill and tap new threads and grinding down the stud heated the glue/plastic enough to pop out the dowel inside the handle. Gonna attempt to jb weld them back in with threaded holes and use bolts instead of nuts.
  5. Took the door handles off but the studs holding them in were rusted and broke off. Any way I could salvage them?
  6. Decided to tackle the indexing and after setting #1 to tdc and cutting the cap I installed the cap to see where it lines up and it seems pretty accurate to me. Wondering if it would be worth continuing or not.
  7. Looks like a torx in the center. Can't say what size since my drain and fill are both hex plugs
  8. Yep, noticed that too which is great 👍
  9. As for the leaf springs, do you just swap it under with the same hardware?
  10. More pictures. Looks like the bracket for the brakes lines over the rear axle was removed to account for the height. Is there somewhere that would indicate wether I'll need brake lines?
  11. I put a link to imgur but it must not be showing. https://imgur.com/a/G0a6VEj I can take different pics if you need something specific
  12. I've got a 1990 Comanche that has a 5.5in Rubicon express suspension lift and I'd like to return the the truck back to stock height. Its pretty clear by the silver paint which parts in the front end were part of the lift kit and would likely need to be replaced (maybe certain parts could remain?). The rear I'm not so sure, are new leaf springs in order? Is it as simple as just replacing parts back to original or is there anything I need to be concerned about? https://imgur.com/a/G0a6VEj
