jdog
    2
Everything posted by jdog
  1. Going down a hill with a back wind
  2. https://www.quadratec.com/p/omix-ada/door-lock-cylinder-kit-76-90-jeep-cj-cherokee-xj-wrangler-yj Or you can use the newer lock style with the double-sided key, just be careful as not all are the same size,
  3. Picture of what your looking for? Different people call things different
  4. jdog
    CC cookbook
    anybody got any desserts?
  5. I've got a parts cluster that has a working fuel gauge if you want to swap it out
  6. did you grab the tow hooks?
  7. That's the one, two wires run to the trans, the other are jumpered together
  8. Wish I had a answer for you, I have not used them so I cannot say
  9. Build day April 19/05
  10. Yep, factory 2wd
  11. thats up to you, only way I know how to check it is with a scanner.
  12. Check the 02 sensor Also fuel pressure
  13. Ashtray for the cup holder and a cig lighter. We got a few in rental cars, always strange
  14. https://youtu.be/HtkGluLhnGU
  15. hey Pete have you added this to the registry yet?
  16. But it should be a four pin weather pak to a two pin connector, the other two wires on the weather pak is a jumper
  17. What about a voltage drop across the starter, pos. To terminal, neg to case.
  18. There should be a jumper wire to go from the connector to the switch
  19. Right side of the engine should be near the firewall and heater hoses, there will be a plug
  20. that sucks the bank still owns it, but good to hear its not going to the crusher
  21. Yea glad to hear you had a safe trip
