2
Everything posted by jdog
build date: 11/15/91 body style: MJJL61 APASMonotone Paint BGASPower Front Disc/Rear Drum Brake DGSS4-Speed Automatic AW4 Transmission DHASLock-Up Torque Converter DHNS-Command-Trac Part Time 4WD System DJHS-230MM Front Axle DMDS-3.55 Rear Axle Ratio DRJS-175MM Rear Axle GACS-Tinted Glass Windows GBBS-Tinted Windshield Glass GCBS-Front Door Tinted Glass HCDS-Do Not Use - See HCA JAZS-DO NOT USE - See JP, KA classes JCAS-85 MPH Primary Speedometer KWRS-STRIPE/BADGE/MOLDING/COLOR K3ZS-STRIPE/BADGE/MOLDING/COLOR LBCS-Glove Box Lamp LMAS-Halogen Headlamps MB1S-Black Front Bumper MFFS-Black Grille MMCS-Rear Door Solid Window Insert MMGS-Belt Moldings NAAS-Federal Emissions NBKS-EVAP Control System NF2S-18.5 Gallon Fuel Tank QE4S-Colorado Red TBMS-Tire Carrier Winch XBSS-Pickup Box YAAS-Build To U.S. Mkt. Specification Z5AS-GVW/Payload Rating 1AAS-U.S. Dealer Retail 142S-Zone 42-Detroit *C1-DESCRIPTION NOT AVAILABLE -SA-Charcoal ADH-Heavy Duty Electrical Group ADLP-Skid Plate Group ALAP-SE Decor Group AWE-Night Eagle Package BARP-90 Amp Alternator BCDP-500 Amp Maintenance Free Battery CBAP-Straight Back Bench Seat CKAP-Carpets - Floor and Cargo Area DGB-All 4-Speed Automatic Transmissions DHTP-Elec,Shift-on-the-Fly,P/Time T/Case ERH-4.0L I6 Power Tech Engine GEC-Front Left Side Sliding Window GFD-Rear Sliding Window GRZP-Left Remote Mirror GSZP-Right Remote Control Mirror GTZP-Manual Remote Mirrors JHAP-Var Intermittent Windshield Wipers JJAP-Cigar Lighter KERP-DESCRIPTION NOT AVAILABLE MBJP-Black Powder Coated Front Bumper MDA-Front License Plate Bracket MHAP-Black Windshield Moldings MMKP-Lower Grille Surround-Painted Silver NHBP-Auxiliary Transmission Oil Cooler NMCP-Heavy Duty Engine Cooling PE4-Colorado Red RAAC-All Radio Equipped Vehicles RAFP-AM/FM Cassette Radio RCDP-4 Speakers SBAP-Power Steering SCGP-Leather Wrapped Steering Wheel SFDP-Front Extra HD Shock Absorbers SGDP-Rear Extra HD Shock Absorbers SUA-Tilt Steering Column TBBP-Full Size Spare Tire TRNP-P225/75R15 OWL Wrangler AT Tires TZAP-Goodyear Brand Tires WJDP-15X7.0 Styled Steel Wheels WLYC-All Steel Wheels XEAP-Tow Hooks YEP-Manuf Statement of Origin YGEA-5 Additional Gallons of Gas Z01P-Rear Spring Group I Z66P-Left Front Group XV Z82P-Right Front Spring Group XI 2TCA-Customer Preferred Package 2TC 26C-Customer Preferred Package 26C 3VNA-Customer Preferred Discount 4M1P-Retail to Bid Diversion Tracking
Driving on the street to street truck
jdog replied to 70barracuda's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Shiny and looks very nice -
Bringing 87 Comanche back from the grave
jdog replied to Liketosmash's topic in Member Projects: Your Comanches
If You're going with the auto column make sure you disable the key release. It's a rod at the bottom of the collar about midway down the column. -
Uh oh be careful that's a slippery slope, now it's just a idler pulley, next week it'll be a bed
I'll take whichever size gets chosen, need more garage art
oe is champion 412, brand is a personal choice. just as long as its a copper core
Next question is did this start after the plugs, but as Pete says plugs are cheap and easy on this one
Altho I do gotta ask why platinum plugs? If you don't mind me asking
Nope you can Reinstall, it will be later today before I can get to a manual to inform you how to test the cmp
Just wanted to make sure you weren't shipping posters
Is there any way to find out from where was first sold my Comanche?
jdog replied to TicoComanche's topic in The Pub
pm me and Ill get you a dealer name -
Glad to hear you got it
that sucks Pete, at least its not its a small world
FYI for those who really want to know pm me and ill see if the infos there, -
same, its also how i figured out the sticker on my airbox was from the selling dealer -
I believe its four not including those two torx, the starter and the inspection cover
did you get the top two torx, if not a really long (like 3ft) extension and a wobble
Your truck was sold in Mass. About all I can divulge, the reason it's not provided as its could be personal info especially with one's that are original owners. -
Grounds and general wiring.
jdog replied to Jeep Driver's topic in MJ Tech: DIY Projects and Write-Ups
Cruiser54 knows I believe -
Pull the white center out, after that you should be able to see the lock
as in dealer, state? -
Switching doors, opinions please
jdog replied to rylee144's topic in MJ Tech: Modification and Repairs
Had a xj with the wing windows, had $0.52 in each latch to keep it from leaking, ended up switching to solids after someone broke the window to steal it. solid windows in the mj and no leaks, if you use the wing windows a-lot you notice the missing airflow at first but the benefits of no leaks a little more rewarding. -
you can ohm from the socket to the harness side of that connector and see if you have the correct wire
