jdog
    2
Everything posted by jdog
  1. jdog
    CC cookbook
    update, It was good, had enough left over to make a sandwich for lunch, now I gotta figure out how to make sticky rice
  2. does this mean they go to the floor? or is the pedal just hard to press?
  3. jdog
    1JTMW6458JT182828
    build date: 4/18/88 body style: ts61 *Q7-Cloth Low-Back Bucket Seats -SA-Charcoal ADA-Light Group AGD-SXT Plus Group APA-Monotone Paint BCQ-750 Amp Maintenance Free Battery CAC- Bucket Seats CGW- CKA-Carpets - Floor and Cargo Area CUF-Full Length Floor Console DDJ-DESCRIPTION NOT AVAILABLE DSA-Anti-Spin Differential Rear Axle DTA-DESCRIPTION NOT AVAILABLE ERB-4.0L I6 Engine GAC-Tinted Glass Windows GEC-Front Window GFD-Rear Sliding Window GTZ-Manual Remote Mirrors HAA-Air Conditioning JFH-Tachometer JGB-Digital Clock JHA-Var Intermittent Windshield Wipers JJA-Cigar Lighter K60-STRIPE/BADGE/MOLDING LAP-Shift Indicator Warning Lamp LDA-Underhood Lamp LMA-Halogen Headlamps LNJ-Front Fog Lamps LPE-Cargo Lamp MBJ-Black Front Bumper MCA-Rear Body Color Applique MCB- Fascia Applique MDA-Front License Plate Bracket MWB- Tailgate NAA-Federal Emissions NHM-Speed Control NHQ-Transmission Heater NMB-Standard Duty Engine Cooling PX6-DESCRIPTION NOT AVAILABLE QX6-DESCRIPTION NOT AVAILABLE RAF-AM/FM Cassette Radio SBA-Power Steering SCG-Leather Wrapped Steering Wheel SUA-Tilt Steering Column TBB-Full Size Spare Tire WJH-15X7 Aluminum Wheels 3LY-DESCRIPTION NOT AVAILABLE Not all codes are accurate
  4. No problem, let us know what you find out what the noise is.
  5. Welcome, start a build thread and add it to the registry. I cannot comment on the repair of the dash, replacement isn't bad harder part will be finding that color, not impossible. Any xj from 86-96 will work for the dash replacement, don't forget to pull your Vin plate and put onto the replacement dash
  6. I would suspect that u joint, you can have someone spin it and recreate the noise while listening for it with a piece of hose or a stethoscope to verify where the noise is at.
  7. Which u joint are you checking? The one at the front diff or the one behind the hub?
  8. u-joint in the front axle or a bad wheel hub, some more info about the vehicle would be super helpful
  9. jdog
    1j7fj26l4kl483561
    you have a recall for the 02 sensor still needing to be done build date 11/22/88 body style jl61 APAS-Monotone Paint BGAS-Power Front Disc/Rear Drum Brakes BJAS-DESCRIPTION NOT AVAILABLE BKPS-10x2.5 Rear Drum Brakes CSRS-Passenger Assist Handles CUMS-Mini Floor Console DHNS-Command-Trac Part Time 4WD System DJHS-230MM Front Axle DMMS-3.07 Rear Axle Ratio GACS-Tinted Glass Windows GBBS-Tinted Windshield Glass GCBS-Front Door Tinted Glass GEHS-Fixed Door Vent Glass GNAS-Rear View Day/Night Mirror JAAS-Instrument Panel JBFS-Instrument Panel Black Bezel JCAS-85 MPH Primary Speedometer JKBS- KDAS-STRIPE/BADGE/MOLDING/COLOR K3ZS-STRIPE/BADGE/MOLDING/COLOR LAFS-Seat Belt Alert-Driver Seat only LAPS-Shift Indicator Warning Lamp LBCS-Glove Box Lamp LCJS-Overhead Lighting LMAS-Halogen Headlamps MB1S-Black Front Bumper MFFS-Black Grille MHBS-Bright Windshield Moldings MMCS-Rear Door Solid Window Insert MMGS-Belt Moldings MMJS-Molded-In-Color Fender Flares NBAS-Underground Calibration NBKS-EVAP Control System NDAS-Catalytic Converter NF2S-18.5 Gallon Fuel Tank QWBS-DESCRIPTION NOT AVAILABLE RACS-AM MTR Radio SCBS- Steering Whl SFAS-Standard Duty Front Shock Absorbers SGAS-Standard Duty Rear Shock Absorbers TBMS-Tire Carrier Winch WJKS-15X6.0 Styled Steel Wheels WMCS-Open XBSS-Pickup Box XFAS-(-35F) Protection Anti-Freeze YAAS-Build To U.S. Mkt. Specifications Z5AS-GVW/Payload Rating 1AAS-U.S. Dealer Retail 174S-Zone 74-Denver *B1-DESCRIPTION NOT AVAILABLE -Q8-DESCRIPTION NOT AVAILABLE BAYP-105 Amp Alternator BCYP-95 Amp Battery CBAP-Straight Back Bench Seat CKA-Carpets - Floor and Cargo Area DBBC-All Manual Transmissions DDX-5-Speed HD Manual Transmission DRKP-Dana 44/226MM Rear Axle DSA-Anti-Spin Differential Rear Axle EAAC-All Engines ERB- 4.0L I6 MPI Engine GFD-Rear Sliding Window GRZP-Left Remote Mirror GSZP-Right Remote Control Mirror GTZ-Manual Remote Mirrors HAA-Air Conditioning JAY-DO NOT USE - See JP, KA classes JGBP-Digital Clock JHA-Var Intermittent Windshield Wipers JJA-Cigar Lighter MDAP-Front License Plate Bracket NAF-High Altitude Emissions NHM-Speed Control PWB-DESCRIPTION NOT AVAILABLE RAAC-All Radio Equipped Vehicles RCAP- SBAA-Power Steering SUA-Tilt Steering Column TAAC-All Tires TBB-Full Size Spare Tire TNCA-P195/65R15 BSW AS Touring Tires YGBA-1 Additional Gallons of Gas YGGA-9 Additional Gallons of Gas Z01P-Rear Spring Group I Z66P-Left Front Group XV Z85P-Right Front Spring Group XIV 5ALA-DT-Vehicle Family
  10. jdog
    1J7FT26L1KL475069
    build date 12/7/88 body- tl62 APAS-Monotone Paint BAQS-115 Amp Alternator BCXS- Maint. Free Battery BGAS-Power Front Disc/Rear Drum Brakes BJAS-DESCRIPTION NOT AVAILABLE BKPS-10x2.5 Rear Drum Brakes CSRS-Passenger Assist Handles DGSS-4-Speed Automatic AW4 Transmission DHAS-Lock-Up Torque Converter DMDS-3.55 Rear Axle Ratio DRJS-175MM Rear Axle GACS-Tinted Glass Windows GBBS-Tinted Windshield Glass GCBS-Front Door Tinted Glass GEHS-Fixed Door Vent Glass GNAS-Rear View Day/Night Mirror HCDS-Do Not Use - See HCA JAAS-Instrument Panel JAZS-DO NOT USE - See JP, KA classes JBFS-Instrument Panel Black Bezel JCAS-85 MPH Primary Speedometer JKBS-hook latch KWXS-DESCRIPTION NOT AVAILABLE K3ZS-STRIPE/BADGE/MOLDING/COLOR LAFS-Seat Belt Alert-Driver Seat only LBCS-Glove Box Lamp LCJS-Overhead Lighting LMAS-Halogen Headlamps MB1S-Black Front Bumper MFFS-Black Grille MHBS-Bright Windshield Moldings MMCS-Rear Door Solid Window Insert MMGS-Belt Moldings MMJS-Molded-In-Color Fender Flares NBAS- NBKS-EVAP Control System NDAS-Catalytic Converter NF5S-23 Gallon Fuel Tank QWBS-DESCRIPTION NOT AVAILABLE RACS-AM MTR Radio SCBS- Steering Whl SFAS-Standard Duty Front Shock Absorbers SGAS-Standard Duty Rear Shock Absorbers TBCS-Compact Spare Tire TBMS-Tire Carrier Winch WJKS-15X6.0 Styled Steel Wheels XBSS-Pickup Box XFAS-35F Protection Anti-Freeze YAAS-Build To U.S. Mkt. Specifications Z1AS-GVW/Payload Rating 1AAS-U.S. Dealer Retail 173S-Zone 73-San Francisco 4AFS-American Coin Merchandising *F2-DESCRIPTION NOT AVAILABLE -Q8-DESCRIPTION NOT AVAILABLE CBAP-Straight Back Bench Seat CKA-Carpets - Floor and Cargo Area DGB-All 4-Speed Automatic Transmissions DHTP- EAAC-All Engines Erb-4.0L I6 Engine GRZP-Left Remote Mirror GSZP-Right Remote Control Mirror GTZ-Manual Remote Mirrors JJA-Cigar Lighter MDAP-Front License Plate Bracket NAE-California Emissions PWB-DESCRIPTION NOT AVAILABLE RAAC-All Radio Equipped Vehicles RCAP-Audio SBAA-Power Steering TAAC-All Tires TNCA-P195/65R15 BSW AS Touring Tires YGBA-1 Additional Gallons of Gas YGGA-9 Additional Gallons of Gas Z01P-Rear Spring Group I Z59P-Left Front Spring GroupIx Z78P-Right Front Spring Group VIII 5ALA-DT-Vehicle Family
  11. Looks like he's applying air to the sensor
  12. jdog
    CC cookbook
    gonna try this tomorrow https://www.allrecipes.com/recipe/222403/homestyle-kalua-pork-with-cabbage-in-a-slow-cooker/?did=533704-20200614&utm_campaign=alrcom-daily-dish_newsletter&utm_source=allrecipes.com&utm_medium=email&utm_content=061420&cid=533704&mid=35380597729
  13. body style: tl61 build date 2/9/88 *B1-DESCRIPTION NOT AVAILABLE -SA-Charcoal AGC- APA-Monotone Paint CBA-Straight Back Bench Seat CGX-RR Head Restraints Outboard Seating DCB-Open EPD-DESCRIPTION NOT AVAILABLE GAC-Tinted Glass Windows GSC-Right Black Mirror JJA-Cigar Lighter LAP-Shift Indicator Warning Lamp LMA-Halogen Headlamps NAA-Federal Emissions PE4-Colorado Red QE4-Colorado Red TBG-Compact Spare Tire WMC-Open
  14. The one in the pan is either a oil temp or level sensor, the one in the block is probably a knock sensor, id just go get a aftermarket gauge set, run a mechanical oil and temp gauge, a bit more accurate than the electric dash ones
  15. Does it flash if your not on the brakes, do the brake lights and running lights work? Stupid question what bulbs are in it
  16. Nope, it be the one at the oil filter
  17. No problem
  18. https://www.ebay.com/itm/Bishko-OEM-Maintenance-Owners-Manual-Bound-for-Jeep-Comanche-1988/273446646817?fits=Year%3A1988|Model%3AComanche&epid=519294459&hash=item3faab0b421:g:kxsAAOSwrhNceOW8
  19. dana 35 and a 5 speed manual
  20. Yep, just up and out of the way of water
  21. Looks like a dealer installed ac you'll be able to clean it up
  22. And the first picture is the e brake cable
  23. The line super stretched is the brake line, the "vacuum line" is a vent hose from the diff
  24. Don't clamp the line, that can cause damage to the internal part of the line. You have to bleed the system anyways its not gonna be much different
