jdog
    2
Everything posted by jdog
  1. jdog
    1JTML6317HT086755
    Welcome, ps your grille is upside down
  2. Congratulations
  3. The autos are nice, aisin Warner aw4 they don't seem to have very many issues unless you really beat on them. You can bolt the amc904/727 if you want to, but you'd be loosing overdrive. There was a race truck posted with that install, but that was a race truck. As far as manuals goes, half way thru 1989 they switched from the weak Peugeot trans to the ax15. Both trans will work but the ax is the better option. Most people will swap in a ax when the Peugeot goes out so don't always assume what the truck has under it.
  4. What pump did you put in there?
  5. jdog
    New Member
    That is nice
  6. Bulb check, and a update. Pulled the cluster to inspect and diagnose the no temp gauge issue, it is the temp gauge, and all the spares I have are bad as well. Oh well, I'll gather the good gauges and send em off for repair soon. As for now it'll get a mechanical gauge. Also fixed a no charge issue, rear brakes, axle seals, and atm waiting for ups to bring me a fuel sender so I can reinstall the tank. They are finally starting the races slowly and Sunday is the Mopar event. If all goes well it should be there on Sunday. Gotta see if I can match pops et time of 26secs lol he ran it out of fuel. It's going to be a bit strange first year in ten years that I'm going without him.
  7. jdog
    New Member
    Welcome, got anymore pictures, from what I can see it looks nice
  8. jdog
    1JTMG641UHT135233
    1JTMG6410HT135233 build 3/27/87 tl61 body style *X1-DESCRIPTION NOT AVAILABLE -YY-DESCRIPTION NOT AVAILABLE APA-Monotone Paint BCQ-750 Amp Maintenance Free Battery CBA-Straight Back Bench Seat CGX-RR Head Restraints Outboard Seating DGS-4-Speed Automatic AW4 Transmission ERB-4.0L I6 Engine GAC-Tinted Glass Windows GEC-Front Left Side Sliding Window GFD-Rear Sliding Window GPB-Blind Spot,Pwr,Fold Pursuit Mrrs HAA-Air Conditioning HCC-Do Not Use - See HCA JHA-Var Intermittent Windshield Wipers JJA-Cigar Lighter LMA-Halogen Headlamps MBJ-Black Powder Coated Front Bumper MDA-Front License Plate Bracket NAA-Federal Emissions PE4-Colorado Red QE4-Colorado Red RCA-19 SPKRS SRT High Perf Audio SBA-Power Rack and Pinion Steering TBG-Compact Spare Tire TBL-Inside Mounted Spare Tire WJN-15 Aluminum Wheels 3LQ-DESCRIPTION NOT AVAILABLE
  9. jdog
    1JTMP6310HT189651
    build : June 25, 1987 body jl61 *A6-Vinyl Trimmed Bucket Seats -H9-DESCRIPTION NOT AVAILABLE APA-Monotone Paint BCQ-750 Amp Maintenance Free Battery CBA-Straight Back Bench Seat CGX-RR Head Restraints Outboard Seating DGW-4-Spd. Automatic 4RE Transmission ERB-4.0L I6 Engine GAC-Tinted Glass Windows GEC-Front Left Side Sliding Window GFD-Rear Sliding Window HAA-Air Conditioning HCC-Do Not Use - See HCA JJA-Cigar Lighter LMA-Halogen Headlamps MBJ-Black Front Bumper MDA-Front License Plate Bracket NAA-Federal Emissions PYC-Amp'd QYC-Amp'd SBA-Power Steering TBG-Compact Spare Tire TBL-Inside Mounted Spare Tire WMC-Open 3LR-DESCRIPTION NOT AVAILABLE
  10. I do, i don't think ive actually used ps fluid in any of my vehicles
  11. https://ezred.com/product/14-mini-master-set/ does this count?
  12. Let those that are gone not be forgotten
  13. Pictures and motor and trans?
  14. It just needs this small part and that's it, it runs great otherwise
  15. What I don't get is they say it's dirty and will clean up but I'm not cleaning it
  16. https://www.ebay.com/itm/202996312271
  17. I think the switch was with the body style change, so 97
  18. @Pete M please move to tech You can either set up a aftermarket like painless wiring fuse block, or get one from a auto. from a salvage yard, either you are going to have to move terminals or splice the wires. If you are going to do the 97+ swap, I would swap everything
  19. Do you still have the ballast?
  20. Put tires on it and drive it, cars are meant to be used
  21. paypaled ya for 2 one of each
  22. build date: 2/22/91 APAS-Monotone Paint BGAS-Power Front Disc/Rear Drum Brakes DGSS-4-Speed Automatic AW4 Transmission DHAS-Lock-Up Torque Converter DMDS-3.55 Rear Axle Ratio DRJS-175MM Rear Axle GACS-Tinted Glass Windows GBBS-Tinted Windshield Glass GCBS-Front Door Tinted Glass GEHS-Fixed Door Vent Glass JAZS-DO NOT USE - See JP, KA classes JCAS-85 MPH Primary Speedometer K3RS-STRIPE/BADGE/MOLDING/COLOR LBCS-Glove Box Lamp LMAS-Halogen Headlamps MB1S-Black Front Bumper MFFS-Black Grille MMCS-Rear Door Solid Window Insert MMGS-Belt Moldings NAAS-Federal Emissions NBKS-EVAP Control System NF2S-18.5 Gallon Fuel Tank QE4S-Colorado Red SCES-Wrapped Steering Wheel SFAS-Standard Duty Front Shock Absorbers SGAS-Standard Duty Rear Shock Absorbers TBCS-Compact Spare Tire TBMS-Tire Carrier Winch XBSS-Pickup Box YAAS-Build To U.S. Mkt. Specifications Z1AS-GVW/Payload Rating 1AAS-U.S. Dealer Retail 142S-Zone 42-Detroit *B1-DESCRIPTION NOT AVAILABLE -SA-Charcoal ALN-Body Color Bumper Group ARLA- BAFP-130 Amp Alternator BCDP-500 Amp Maintenance Free Battery CBAP-Straight Back Bench Seat CKAP-Carpets - Floor and Cargo Area DGB-All 4-Speed Automatic Transmissions DHTP- ERH-4.0L I6 Power Tech Engine GFDA-Rear Sliding Window GRZP-Left Remote Mirror GSZP-Right Remote Control Mirror GTZA-Manual Remote Mirrors HAA-Air Conditioning JHAA-Var Intermittent Windshield Wipers JJAP-Cigar Lighter KKSP-STRIPE/BADGE/MOLDING/COLOR KWSP-STRIPE/BADGE/MOLDING/COLOR K2BP-STRIPE/BADGE/MOLDING/COLOR K27P-Do Not Use MBJP-Black Bumper MHAP-Black Windshield Moldings MMKP- PE4-Colorado Red RAAC-All Radio Equipped Vehicles RAFA-AM/FM Cassette Radio RCDP-4 Speakers SBAP-Power Steering TMWA-Tires TZHP-Michelin Brand Tires WJDP-15X7.0 Styled Steel Wheels WLYC-All Steel Wheels YGEA-5 Additional Gallons of Gas Z01P-Rear Spring Group I Z58P-Left Front Spring Group Viii Z78P-Right Front Spring Group VIII 3V3A-Customer Preferred Discount
