jdog
    2
Everything posted by jdog
  1. the plugs will tell us if it is running rich and which cylinders, they could be showing us that its running rich without giving fits
  2. with the fuse added, did you connect it to the 4 wire connector?
  3. unless you like the smokers window, replace it with solid windows, iirc no full windows before 97
  4. I really want to know if the sunroof was a option in the movie
  5. This wouldn't be named after goonies?
  6. can you pull a plug or two and see how they look.
  7. What doesn't work besides the wipers, also are you just wanting the radio to work?
  8. Projects been on hold lately, but I got the radiator back from the radiator shop, and installed, disc brakes are installed, pads are here, waiting for new hoses. my list is short and its almost car show season.
  9. 9/14/88 build date body-MJJL61 *X2 DESCRIPTION NOT AVAILABLE -Q8 DESCRIPTION NOT AVAILABLE ADL Skid Plate Group BAYP 105 Amp Alternator BCYP 95 Amp Battery CBAP Straight Back Bench Seat DGB All 4-Speed Automatic Transmissions DHTP Elec,Shift-on-the-Fly,P/Time T/Case DRKP Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle EAAC All Engines EAFC 1.4L I4 16V MultiAir Turbo Engine ERB 4.0 Engine GFD Rear Sliding Window GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning PQ9 DESCRIPTION NOT AVAILABLE RAAC All Radio Equipped Vehicles RAB AM/FM Radio RCDP 4 Speakers SBAA Power Steering TAAC All Tires TBB Full Size Spare Tire TNCA P195/65R15 BSW AS Touring Tires XEEP Fuel Tank Skid Plate Shield XEFP Transfer Case Skid Plate Shield XEUP Front Suspension Skid Plate YGGA 9 Additional Gallons of Gas Z01P Rear Spring Group I Z67P Left Front Spring Group XVI Z86P Right Front Spring Group XV 4HC Special Scheduling Condition III 5ALA DT-Vehicle Family APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CKJS Black Vinyl Floor Covering CSRS Passenger Assist Handles DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMDS 3.55 Rear Axle Ratio GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror JAAS Instrument Panel JAZS DO NOT USE - See JP, KA classes JBFS Instrument Panel Black Bezel JCAS 85 MPH Primary Speedometer JKBS KDCS DESCRIPTION NOT AVAILABLE K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS Bright Windshield Moldings MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares NAAS Federal Emissions NBAS Underground Calibration NBKS EVAP Control System NDAS Catalytic Converter NF2S 18.5 Gallon Fuel Tank QQ9S DESCRIPTION NOT AVAILABLE SCBS Perforated Steering Whl w/Red Stitch SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels WMCS Open XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 165S Zone 65-New Orleans
  10. wonder if that means when he joins if he will get the label cannot spell comanche?
  11. perform a pressure test on the cooling system, pretty sure you can rent the tools but don't quote me on that. get the system pressurized and let it sit and see if it drops, if so start looking for coolant drips if not pressurize the cap, just cause its new doesn't mean its good.
  12. Found this on craigslist
  13. jdog
    CC cookbook
    made this the other night, it was quite tasty. saving it for future meat loafs
  14. jdog
    1JTHS64P6JT210026
    build date 5/20/88 body style MJTM61 *X1-DESCRIPTION NOT AVAILABLE -H9-DESCRIPTION NOT AVAILABLE AGJ-Driver Assistance Group APA-Monotone Paint BCQ-750 Amp Maintenance Free Battery CBA-Straight Back Bench Seat CGX-RR Head Restraints Outboard Seating CKA-Carpets - Floor and Cargo Area DCB-Open EPD-DESCRIPTION NOT AVAILABLE GAC-Tinted Glass Windows GFD-Rear Sliding Window GSC-Right Black Mirror HAA-Air Conditioning JHA-Var Intermittent Windshield Wipers JJA-Cigar Lighter K60-STRIPE/BADGE/MOLDING LAP-Shift Indicator Warning Lamp LMA-Halogen Headlamps MBJ-Black Powder Coated Front Bumper NAA-Federal Emissions NMB-Standard Duty Engine Cooling PWB-DESCRIPTION NOT AVAILABLE QWB-DESCRIPTION NOT AVAILABLE RAB-AM/FM Radio SBA-Power Steering SCE-Alcantara Wrapped Steering Wheel SUA-Tilt Steering Column TBB-Full Size Spare Tire WJD-15X7.0 Styled Steel Wheels 3LX-DESCRIPTION NOT AVAILABLE
  15. jdog
    1JTMW64PXjT198319
    build date 05/5/88 body style MJTM61 *X1-DESCRIPTION NOT AVAILABLE -SA-Charcoal AGJ-Driver Assistance Group APA-Monotone Paint CBA-Straight Back Bench Seat CGX-RR Head Restraints Outboard Seating CKA-Carpets - Floor and Cargo Area DDJ-DESCRIPTION NOT AVAILABLE ERB-4.0 Engine GAC-Tinted Glass Windows GEC-Front Left Side Sliding Window GFD-Rear Sliding Window GSC-Right Black Mirror JFH-Tachometer JGB-Digital Clock JHA-Var Intermittent Windshield Wipers JJA-Cigar Lighter K60-STRIPE/BADGE/MOLDING LAP-Shift Indicator Warning Lamp LMA-Halogen Headlamps MBJ-Black Powder Coated Front Bumper MDA-Front License Plate Bracket NAA-Federal Emissions NHQ-Transmission Heater NMB-Standard Duty Engine Cooling PS4-Bright Platinum Metallic Clear Coat QS4-Bright Platinum Clear Coat RAB-AM/FM Radio SBA-Power Steering SCE-Alcantara Wrapped Steering Wheel TBB-Full Size Spare Tire WJD-15X7.0 Styled Steel Wheels 3LX-DESCRIPTION NOT AVAILABLE
  16. jdog
    1JTHW64S3HT049930
    build date 10/30/86 body: MJTH61 *X8-Cloth Low-Back Bucket Seats -YY-DESCRIPTION NOT AVAILABLE ADA-Light Group AGI-DESCRIPTION NOT AVAILABLE AHL-Heavy Duty Insulation Group APA-Monotone Paint CAC-Low Back Bucket Seats CGW- CKA-Carpets - Floor and Cargo Area CLE-Front Rear Floor Mats CUF-Full Length Floor Console DDJ-DESCRIPTION NOT AVAILABLE ERB-4.0 Engine GAC-Tinted Glass Windows GEC-Front Left Side Sliding Window GFD-Rear Sliding Window GSC-Right Black Mirror HAA-Air Conditioning HCC-Do Not Use - See HCA JAY-DO NOT USE - See JP, KA classes JFH-Tachometer JGB-Digital Clock JHA-Var Intermittent Windshield Wipers JJA-Cigar Lighter LAP-Shift Indicator Warning Lamp LBB-Courtesy Lamps LDA-Underhood Lamp LMA-Halogen Headlamps LNJ-Front Fog Lamps LPE-Cargo Lamp MBJ-Black Front Bumper MCA-front bumper pads MCB- MD8-Delete Front License Plate Bracket MWB-Off Road Truck Tailgate MWF-Adjustable Roof Rail Crossbars NAA-Federal Emissions PYN- QYN- RAF-AM/FM Cassette Radio SBA-Power Steering SCE- Wrapped Steering Wheel TBB-Full Size Spare Tire TBL-Inside Mounted Spare Tire WJN-15 Aluminum Wheels 3LW-DESCRIPTION NOT AVAILABLE
  17. jdog
    1jths641xht157398
    build date 5/1/87 body style MJTL61 *X1-DESCRIPTION NOT AVAILABLE -YY-DESCRIPTION NOT AVAILABLE APA-Monotone Paint CBA-Straight Back Bench Seat CGX-RR Head Restraints Outboard Seating DCB-Manual Transmission EPD-2.5 L Engine GAC-Tinted Glass Windows GPB-Blind Spot,Pwr,Fold Pursuit Mrrs HCC-Do Not Use - See HCA JJA-Cigar Lighter KD8-STRIPE/BADGE/MOLDING/DELETE LAP-Shift Indicator Warning Lamp LMA-Halogen Headlamp MBJ-Black Front Bumper MD8-Delete Front License Plate Bracket NAA-Federal Emissions PE4-Colorado Red QE4-Colorado Red SBA-Power Steering TBG-Compact Spare Tire WM-Open 3LR-DESCRIPTION NOT AVAILABLE
  18. so i looked at it and it is missing the map sensor harness, and the eyelets for the fuse links are cut, would you still want it?
  19. You need to swap oil and temp. Pm replied
  20. I've got both the blank panel and a cluster with gauges, if you want to buy them, your other option would be to install the clock there
  21. 97+ wiper arms work the changed the way they blade mount as well. Better design
  22. But in the description, it says 800 and no surprise being its jeeps unlimited
