I don't have a picture at the moment. but it goes though the upper left side of the timing cover theirs 2 . may or may not have a pulley or bracket attached to it on the front side you may have to remove some things pulleys, fan ect.( I can't remember). Goes through the upper left of the timing cover, the center nut acts as a timing cover bolt it goes though the timing case into the alternator bracket which is on the bottom passenger side which has 2 nuts screw on to the two bolts at the end of the alternator bracket. so you will need a wrench on the back side of the alternator and a wrench or ratchet on the front of the timing cover.
