LEAD_NOT_FOLLOW
Everything posted by LEAD_NOT_FOLLOW
  1. I was told by the local auto parts store that it's a vehicle specific plug and my only option would be the dealer. Upon calling the dealer I was told I'd have to buy an entire vehicle wiring harness (yeah right!). Didn't know if anyone on here worked at a dealer and could look it up to see if you can just by the connectors? I guess my other option is to find someone parting an XJ or a '92 MJ that would have that connector... :grrrr:
  2. My wife's '94 XJ recently lost all parking lights/dash lights. I looked at it today and after removal of the headlight switch I noticed that the connector was melted a bit. I believe this to be the cause of a faulty headlight dimmer/switch. Does anyone know where to purchase a new connector at? It's a 9-terminal connector and plugs directly into the headlight switch/dimmer. I simply just need the plastic connector as it looks like all the wiring/terminals are ok. I believe that it is year specific from '92-96. It plugs into the back of this;
  3. Just a FYI about the YJ yoke... The YJ yoke is longer, however it is not fully splined all the way. So what you gain in length, you loose in spline engagement.
  4. NP231 Service Manual http://www.greatlakesxj.com/tech/NP231-Component-Service-Manual.pdf
  5. Here is a bit of info to help you decide (info provided by each manufacture directly); OEM XJ Coil - 145 BDS 3" XJ Coil - 240 DPG 5" XJ Coil - 198 OME 930 XJ Coil (aprox 2") - 160 OME 934 ZJ Coil (aprox 3" on XJ) - 180 TeraFlex 3.5" XJ Coil - 170 TeraFlex 4.5" XJ Coil - 200 Rustys 3" XJ Coil - 150 Rustys 3" HD XJ Coil - 180 Rustys 4.5" XJ Coil - 150 Rustys 4.5" HD XJ Coil - 180 Rustys 6" XJ Coil - 180 Rustys 9" XJ Coil - 180 Rubicon Express 3.5" XJ Coil - 241 Rubicon Express 4.5" XJ Coil - 169 Rubicon Express 5.5" XJ Coil - 185 Rancho 2.5" XJ Coil - 235 Skyjacker 3" XJ Coil - 218 RockKrawler 3" XJ Coil - 180 RockKrawler 4.5" XJ Coil - 180 RockKrawler 6" XJ Coil - 180 Motion Offroad 3" XJ Coils - 165 Motion Offroad 4.5" XJ Coils - 165 Motion Offroad 6" XJ Coils - 165 REMEMBER THAT THE COIL SPRING RATE DOES NOT DETERMINE 100% OF RIDE QUALITY!!! IT VARIES GREATLY BASED ON THE SHOCKS YOU RUN!!! NOT TO MENTION CONTROL ARM ANGLES!
  6. Far from "identical".... The RE braces mount under the tranny crossmember on the XJ, the RC braces do not go nearly as far back. Also the RE DB's move the location of the LCA further back, the RC one's do not.
  7. WJ coils are a different diameter and will not fit correctly on the XJ/MJ D30 coil buckets.
  8. Spencer @ JeepSticker I've worked with him on several occasions on various projects and he's always done a fantastic job. www.JeepSticker.com
  9. Factory Service Manual (FSM) that has the wiring diagrams. http://www.greatlakesxj.com/tech/95fsm.zip
  10. I do not have the direct answer for you but may be able to help as far as resources go. 1993 XJ FSM - http://www.greatlakesxj.com/tech/93fsm.zip 1999 XJ FSM - http://www.greatlakesxj.com/tech/99fsm.zip Both should have the information your looking for along with wiring diagrams.
  11. There is also a M-715 in that movie;
  12. The biggest issue with it is that it was used with a 6000K winch. I've never had my hands on one; so I do not know if you could fit a larger winch on it or not. But 6000K really isn't a large enough winch for the vehicle.
  13. It's not a '92 if it's an Olympic Edition... It should be an '88
  14. It was manufactured by Ramsey and is no longer available from Jeep or Ramsey. Here are a few .pdf files that may be of interest though; http://www.ramseypdfs.com/owners_search_pdfs/295153-D.pdf http://www.ramseypdfs.com/owners_search_pdfs/Parts%20List-JEEP%20XJ%2084-94%20HIDDEN%20KIT.pdf
  15. Here is the original one; As far as a few other movie's with MJ's... The Big Bounce War of the Worlds The Stupids Dark Blue Small Soldiers Rent Monster's Ball Unidentified
  16. It is controlled on the Transfer Case; not on the axle.
  17. 33x12.5 on a 3.5" RE lift on the wife's XJ (yeah I know it's an XJ, but the front suspension/fenders are the same). Sorry but I don't agree with 95% of the statements above; you don't need large amounts of lift or lots of trimming to fit them. Running stock flares (not relocated) and VERY minimal amount of trimming.
  18. He is on here I believe...
  19. http://greatlakesxj.com/tech/mjrearshock.htm
  20. Should bolt right in. This may be of help; http://www.comancheclub.com/forums/viewtopic.php?f=9&t=8325
  21. http://greatlakesxj.com/tech/mjrearshock.htm
  22. Or adjust the steering stops on the knuckle. Just put a washer behind it.
  23. I guess I'm stupid cause I swapped in an AMC20 into my wheeling MJ... Parts are not at all hard to find. They are an identical housing as a WT CJ AMC20 besides the spring perches and the 1 piece shaft. The reason the shafts are NLA is all the CJ guys bought them to put in their axles to cheaply solve the 2-piece shaft failure issues. Their is a decent amount of aftermarket parts available for them, relatively the same price as any D44 part.
  24. The above pic of the AMC 20 that Dave posted is of my '86 which is NOT a Metric-Ton MJ. We had a discussion about this prior... As far as any additional info, here is an older post of mine in regards to AMC 20's gear ratio's; viewtopic.php?f=2&t=13854
  25. On the wiper arm itself there is a little tab (see green arrow) that you pry out with the straight screwdriver (pry away/out from wiper, not up). Once the tab is out you can lift up on the wiper arms and they should come off. They may be a bit difficult to get off, so take your time and be careful if you try to pry on them.
