socal1200r
socal1200r's Achievements
Comanche Aficionado (4/11)
Greg - just sent you a return email with the attachment...hope it opens up for you okay...
Looks clean to me, only record on it is a loan/lien...shoot me an email to: socal1200r@yahoo.com, and I'll try and reply with the file...
:agree: Get 2" spacers up front, extended greaseable shackles for the back, and you're done. Spacers and shackles can be found on ebay, for less than $100 (altho most likely not from the same seller). This is the lift I was thinking of putting on my MJ, but since I put an airbag helper kit on the back, I'm going to leave it at stock height for now.
What tires are you running?
socal1200r replied to swoop's topic in MJ Tech: Modification and Repairs
31x10.50-15 Firestone Destination AT's on 15x7 Jeep alloys. I believe these Firestones are made in the USA. Got a great deal on them, buy 3 get one free. Second choice would've been Goodyear Wrangler Authority's from Wal-Mart... -
1988 / 2.5 4-cyl / 5-speed / 4.10 gears / 31x10.50s / 16 mpg city & highway driving
I had a Ford Ranger with the 3.0 V6/auto trans, and a Mazda B-series truck (same as Ranger) with the 3.0 V6 and 5-speed. I don't think I ever got higher than 20-22 mpg on the highway with either truck. Usually got in the high teens for mpg, for a combo of city/highway driving. It would be the unusual truck/driver that can get high 20's to low 30's for mpg out of a V6 Ranger. My dad used to have a Ranger with a 4-cyl and auto trans, I'll have to ask him if he remembers what kind of mpg he got.
LOL...that's a good one...his odometer must be in DIRE need of calibration! I usually get half that mpg, for city/highway combo driving.
4.7HO in a Comanche or XJ?
socal1200r replied to knever3's topic in MJ Tech: Modification and Repairs
I've always thought the 5.0 / manual trans out of a Mustang would be an interesting engine/trans swap. There should be plenty of donors like that around, lots of parts available for the 5.0, and being roughly double the size of my 2.5 4-cyl, there should be enough of room in the engine bay? To me, one of the limiting factors has to be the manual transmission. If I wanted to go with an automatic, there would probably be more engine swap possibilities, but in wanting to stay with a manual trans, sort of narrows down the choices. -
Sounds like a good candidate for locking the CAD...
Well, I've had no luck with finding a new oil pan for the 2.5L in my MJ, so it looks like I'll be making a trip to the dealer. I had the oil and filter changed the other day, and the technician who did the work wanted me to see the oil drain plug. It was one of those rubber/brass butterfly nut gizmos, and he said chances are the threads on the drain plug were stripped, that's why one of those things were used. I've got a good-size oil leak now under the oil pan, not sure exactly where it's coming from, but there's oil drops accumulating on the drain plug. It's pretty sludgy underneath there, and the technician said I should install a new oil pan. I asked him how hard it would be to change it, and he said the starter would have to be removed, but other than that, it looked pretty straight-forward. So the local Jeep dealer wants $131 for the oil pan, and hopefully that comes with a drain plug. I'll ask the dealer what a new oil pan gasket would cost, but may end up buying one at the local auto parts store instead. We'll see...
Just checked the TireRack link, those Yokohamas are out of stock. Just for yucks, I chose another brand of tire, just to get the shipping quote, and it would cost over $100 just for shipping. So IF they had a set of 4 of those Yokos in stock, it would cost roughly $625 to get a set of 4 delivered to me. Then I'd have to spend probably another $80-$100 to get them mounted/balanced, which would push the "on the rim" price to around $700. Still think a set of Goodyear Wrangler Authority's from WalMart is a great deal. Those tires in that size (31x10.50) are $130 each, and they'll mount, balance, new valve stems, road hazard, and tire disposal for about $18/tire. So that would be less than $600 for a set of 4 on the rim, with a road hazard warranty. If i didn't get such a good deal on these Firestone Destination AT's, I would've gotten a set of Goodyears from WM...
Death wobble, possible causes?
socal1200r replied to 88MJXLS's topic in MJ Tech: Modification and Repairs
So you have a SOA lift in the back, but nothing up front? I would think that would put even more weight/balance on the front wheels? Also, even though miles-wise your MJ is low for the year, there's a good chance some of those stock rubber bushings need to be replaced, if anything, due to time, not miles. If you're going to put on a new track bar and front shocks anyway, that could go a long way towards fixing the shimmy. However, with the SOA lift in the back, and no lift up front, my guess would be you'll still have some work to do... -
Thanks Paul - I might have to get a used one, if I can't get my hands on a new one at a decent price...
How many miles are on your MJ? I had an aribag helper kit installed on the rear of my MJ, and I got to talking to the mechanic, and he mentioned something about the infamous death wobble. He said people with 100K or higher miles on their Jeeps put on a lift kit, don't replace the bushings, and are surprised when it "shimmys" or "wobbles". I had a '95 XJ that shimmied so bad one time I had to slow down and pull over, it felt like the front end was shaking itself apart. When it did the same thing a few hours later on the return trip, I knew something wasn't right. Not sure what eventually fixed it, but I ended up getting the tires rebalanced, new Bilstein shocks front and back, new steering stabilizer, and had the front end checked out by a reputable off-road shop, who replaced the track bar and some of the bushings. Once all that was done, it never shimmied or wobbled again, and tracked straight and true, even over rough rain grooves, and metal grates on lift bridges.
