RustyRodder
    2
Everything posted by RustyRodder
  1. I painted mine 92 sand beige and love it. but out of your choices, red
  2. Is it better to PM or Email you?
  3. Id love to put one on mine.
  4. Likewise, my 88 windshield came out, 98 windshield/trim went in.
  5. I have a set of remote spotlights from a boat- I like them. 70* up/down and 380* around.
  6. I take it you just stitch weld around the plate on the Crok? Or is it straight bolt on (which I can't imagine makes a difference?) Luckily This truck is never getting anything bigger than 31's so there isnt a ton of stress.
  7. Is the CRok better than the Rustys one I was going to pick up? I only bring up cutting because they use that as an option in the instructions.
  8. Well, I found my truck has the steering box crack while replacing the radiator- the top mounting bolt, about 2" long so far. I am looking at the frame plates, and have a couple questions for anyone thats done them- First, do I have to cut the front off them to use with the stock bumper? it says experience may vary, but I figure somebody out there has done it already with factory bumper/mounting brackets. Second, Do I need to worry unbolting the radiator support brackets with everything still attached?
  9. I remember he started at 2500 a while ago.
  10. Blinker could just be a bad ground/bad socket, and easy fix. Mine was an incorrect bulb in the rear that caused the right signal not to work with the lights on.
  11. I will check the wires- I keep the truck at my parents, so its not right outside sadly. But since it starts, I would guess yes to the CPS bypass.
  12. as far as I know, no. Should note, truck starts and runs fine (or as fine as a renix does)
  13. Working on replacing rotted loom and tidying up, i found these 2 wires off the C101. Are they supposed to connect somewhere? I couldnt find another end. But apparently this section also holds my electrical short, so theres that.
  14. Just looks like it sits further back than mine does
  15. Looks good! but is that a SWB bar? looks like it sits pretty far back!
  16. RustyRodder
    Hello
    Hola
  17. I stand by a Honda- My go-to is an Accord. They don't give up much mpg over a civic, but way more room, comfort, and features. Mine with snow tires never had a problem with upstate NY winters. Currently have a 2014, before that was a 2003, and before that a 94. love the 2014- 280hp and I get 36 on the highway. Otherwise, a CR-V wouldnt be a bad choice. Passport is also good, but its the same as a Isuzu Rodeo- and the 98-02 models had a massive recall due to rust issues underneath.
  18. Whats the plan for that one?
  19. Maybe, but no other ones are my first car!
  20. Been working on my first car. I forgot how much i like it. My ex was surprised when I told her the jeep would go before it.
  21. I have my open cooling 85% done, but I can't drive the Jeep indefinitely due to the bigass crack in the frame by the steering box How did that happenw ith stock tires??
  22. Started my open cooling setup- truck wasnt going over 160 unless sitting, then it goes up to 175 and stabilizes/declines. Expected a stuck open thermostat, but nope (maybe its a 160).
  23. Looking for a XJ/MJ Bull bar (push bar). Not the full width bar, the one that does the grill area only.
  24. 1JTMG64P3JT216284 1988 Jeep Comanche Pioneer (Image to be added) 4.0 / AW4 / D35 2wd model / 3.55 gears / SWB Build date: Unknown, Sticker missing when purchased Current Location: Albany, NY (Original puchase 1988 in Atlanta, GA) Status: Running, Driving on road. Notes: Factory Column Shift/Bench seat[vinyl], AC, Rear slider. Originally Colorado Red w/Grey interior & silver/black pioneer stripes. Now 1992 Sand Beige Metallic w/red striping, grey bucket seat interior. Added Factory Roll Bar. Current owner: Me
  25. Id love that guard... even if its a weld-it-yourself kit
