2
Flex in the fire wall do to rust
schardein replied to Lorenz's topic in MJ Tech: Modification and Repairs
BINGO It's common in the Jeep CJ world to see people convert to a hydraulic clutch (factory option with 4 cylinder models), which is so much better than the stock mechanical linkage (on 6 and 8 cylinder models). What they often forget is the factory bracket that ties the pedal pivot pin into the firewall at the point where the clutch MC is mounted. It also adds convenience, as the studs for the clutch MC are made into the bracket. First pic is a late YJ bracket and an early YJ/CJ bracket (different spacing). next pic is the 86 MJ parts manual, which interestingly, doesn't show a reinforcement bracket. last pic is from 87-90 parts manual, which shows a reinforcement bracket. Can anyone confirm that 84-86 XJ/MJ had the reinforcement bracket? -
I run a Chevy 5.3/Jeep NV3550/Dana 300 in my 83 CJ7. Currently, I use a clocking ring and different input gear in the transfer case (with deeper splines to account for the width of the ring), both from Novak, to get the nearly flat clocking I wanted. But, when I initially put the transmission and transfer case together (in 2007, with a 4.0HO engine), I just re-drilled the transmission flange to use the transfer case at about the factory clocking. It was rather tight, as not much "meat" was available on the flange. But, it worked with no issues and I wheeled the Jeep hard until 2014, when I tore everything down for the 5.3 swap. You should eyeball you flange and see how much material is available. Look on the backside to make sure there are no stiffening ribs in the way. Make a paper template of the original holes or use a gasket as a template if one is available.
I wasn't into cars so much, but I built every Monogram 1/48 scale WWII aircraft they produced, and a bunch of the 1:35 scale armor from Testors and Tamiya. Somewhere I have a box with nearly all the instructions to every armor kit I built, and a collection of those color pamphlets on how to create a diorama that Shep Paine did.
1991-93 parts catalog shows one part number for XJ, MJ, YJ, and ZJ, and a different part number for a mid year change in 93 ZJs.
Upgrading to a Gauge Package W/ Column Shifter
schardein replied to Andy in Pa's topic in MJ Tech: DIY Projects and Write-Ups
The 73-87 Chevy trucks (91 for Suburbans and Blazers) had the gear indicator in the dash panel rather than on the steering column. I think the 72 and earlier trucks had it on the column. -
It was pretty picked over when I got there. But it did have these sometimes hard to find jack mounting/stowage parts. Not shown, I also grabbed the jack crank handle, they are different than the XJ.
If you have pick-n-pull type junkyards near you, you might go check out 70s-80s GM full size vans. They used similar steering column mounted shift indicators. They were lighted from the factory. Older ones will be for 3 speed transmissions (like TH350/TH400) later will be four speed (like 700R4). Here is an example of a 3 speed type. You can see the bulb in the lower bracket that is wired into the dash lighting circuit. You best bet is to find and pull one in a junkyard yourself so you see how they come off/are installed, so you can adapt it to your column. -
Jeep comanche trailer wiring harnesses
schardein replied to 88mjsally's topic in Vendors- members making products for MJs
OK gents, here is an update. I've done some searching and here is what I found: Apparently 1993 Jeep Grand Cherokees (and maybe 94?) used this same plug (male and female) in the tail light wiring. I looked on Rockauto and they have a trailer harness for a 93 GC (WVE brand, part 4T1062) that looks to have the same connectors. Would this part number be a plug and play on a 91-92 Comanche? No idea. Maybe, maybe not, and at $65.99 that's a big gamble. If they aren't plug and play, maybe the connectors could be re-pinned to work? In any case, 1993 (maybe 94) Grands will be the vehicle to find in junkyards, to see if the connectors can be reused for a home brew plug and play trailer harness like the Cadillac connectors are now. -
OK. Is it worth grabbing any of it? MC/Slave/Line?
I think the clock had some flaws that don't show in the picture. I generally only grab them if they are perfect or close to it. What do you mean by the good clutch set up?
Interesting. Can anyone else with a 91-92 MJ confirm that the taillight harness uses a different connector? Hate to say it, but assuming that connector can't be sourced, one option would be to cut that connector out completely, then wire in the Cadillac style connector (either using short pigtail wires and butt connectors, or new terminals crimped on) and then using the readily available Cadillac style trailer wiring harness. Kinda defeats the whole goal of not cutting the factory harness though. -
In the junkyard. Speedway Salvage, East St Louis, 22 Dec 2021. Pretty picked over before I got there.
1983 CJ-7 5.3 Vortec swap
schardein replied to schardein's topic in Member Projects: Other Cool Stuff
I've had a cable operated Ox in the rear D44 since 2006. It's always worked great. I routed the cable carefully and used Adel clamps at a couple points to keep the cable in place. The clamps are loose enough on the cable to allow some movement. I did manage to somehow pinch the cable on the Rubicon Trail in 2019. That made the shifter operation a bit stiffer. I was thinking of replacing the cable, but lately I think it has loosened a little from use, so I'll probably keep running it as is. The front D44 Ox is air operated. I think I posted earlier that I replaced a Detroit Locker with the Ox. It's nice having the option now to be unlocked/locked on the trail. So far it has been flawless in operation. I like the fact that it uses a pneumatic rocker switch, so there are no electrical relays to be a potential problem. I routed the air lines carefully, as any time I've seen an air locker fail on the trail, it was most often because of a damaged line from a sloppy installation. I carry an air line repair kit I cobbled together myself, mostly containing parts I got from Mcmaster-Carr. I don't see as many Ox Lockers on the trail as ARB or factory Rubicon lockers, but everyone I talk to that has one, likes them. -
Cluster swap from '96 to '91
schardein replied to acfortier's topic in MJ Tech: Modification and Repairs
You might want to confirm that the warning lights in the side panel are the same between the clusters. Seems like I have noticed differences in those panels. The differences are probably between Renix years and HO years, but might still check to be sure. -
There is another way. I switched out my original 91 cluster for a 120mph police cluster. I wanted to maintain the correct odometer reading right down to the tenth. What I did was disassemble a spare speedometer to get a small shaft with an attached gear out. This shaft is what drives the odometer. Then I disassembled the speedometer I was going to use, just enough to separate the driving gear from the driven gear of the odometer. I clamped the shaft and attached gear in my corded drill. I sat the speedometer on a folded towel. I adjusted the trigger of the drill so it turned at a fairly slow rate of speed. Then I laid it on a folded towel and adjusted the level so the gear in the drill engaged the gear on the speedometer. Then I turned the drill on and locked the trigger down with the trigger lock. I watched it for a few minutes to get an idea of the rate it was moving the speedo. Then I simply checked it every 5 minutes or so until it was close, and stopped it on the exact mileage, to the tenth. I didn't take any pictures of the process. But I might still have that shaft and gear in my box of gauge stuff. It probably sounds janky, but worked like a charm. -
Yep there is a vacuum operated flap as others have said. I've noticed in my XJ that if I shut off the engine and sit for about 5 minutes, the vacuum bleeds off enough to allow that door to either open or close, whichever way it is spring loaded. I clearly hear it.
Hmmm I have a spare bumper
The problem is the headlight buckets stick out the back quite a bit. The fender mounting points do not sit flush against the wall. I'm not going to mod the parts, I might need to bolt them on someday!
Yep time for rebuild. Was there any noticeable metal in the oil? Does the pinion have any play? Turns smooth?
91 HO Shut Off While Driving
schardein replied to kryptronic's topic in MJ Tech: Modification and Repairs
The camshaft sensor in my 91 XJ would cause a hot shut down. When it cooled off, the truck would start and run again. I first thought it was a crank sensor, as that had been my previous experience. Also, due to unrelated wiring problems, I couldn't use the "key-on-off-on-off-on" and count the flashes of the check engine light to get the trouble codes from the computer. When I repaired that wiring, I was able to see the computer was throwing the code for the camshaft sensor. I replaced the distributor with a later model one (as others have suggested in this thread) and it cured the problem. Another nice thing about the later distributor is the sensor is replaceable without disassembling the shaft from the distributor housing. Makes it very simple to carry a spare sensor and replace it as a quick test. -
There shouldn't be any side to side movement, or in and out movement. Either would indicate worn carrier bearings, or improper setup. But, if you grasp the ring gear and hold the pinion gear stationary, there should be some slight "play" in the ring gear in relation to the pinion gear, in its normal direction of rotation. This play is called backlash and is part of the ring and pinion setup.
Finally got the last piece I needed to complete this wall hanger. Anyone actually hang one of these? I want to make some sort of bracket to secure it to the wall, rather than just set it on or hang it from screws.
Yep, although I don't know the actual cut off date. This was on an 84.
