6
The space I have to work with is about 16 3/4 inches wide and 9 1/4 inches tall. Cutting the opening and making it bigger is not an option. I was thinking a sill air conditioner would work possibly, but I don’t have any real world experience with them. If that doesn’t work I may be forced to use a portable air conditioner. Thanks for your help as usual
Noob Installs a Manifold Gasket . . .
Strokermjcomanche replied to NC Tom's topic in MJ Tech: Modification and Repairs
Normally I get a small cut off wheel and cut the bolt in between the manifold and the head pipe. Those bolts are spline pressed in and will come out with an air chisel or ball joint press. -
Engine bay reference pics?
Strokermjcomanche replied to jeepmjga's topic in MJ Tech: Modification and Repairs
The red is the power wire for the hood light. The white is the vacuum line for the heater valve -
Reproduction rear window gasket
Strokermjcomanche replied to camjeep3's topic in MJ Tech: Modification and Repairs
X2 I think I even have a new one, not sure if that matters or not. I would want to put it around a piece of glass before sending it to make sure that didn’t shrink at all. -
I will be there. I will either have my black or white Comanche, possibly my white Cherokee. And I’ll have my Comanche camper trailer At the campground
New windshield woes
Strokermjcomanche replied to 70barracuda's topic in MJ Tech: Modification and Repairs
I would check and see if your insurance would cover it.My insurance company will replace the glass for free as I have comprehensive. Especially if it’s got chips\Nicks In your line of sight they typically don’t repair those. I would also advise you To get the molding clips ahead of time as most glass shops don’t have them in stock. The clips (especially if they’re brittle ) will break easily. The clips are only around 20 bucks if you shop around, sometimes cheaper. If i recall correctly you need 17 of them -
I’m almost positive that he does ship. And yes that is the correct place
I would check with Z+M Jeeps in Toledo Ohio. When I was there several years ago picking I believe he had several of the metric clusters. He may not have them anymore but it’s definitely worth a shot.
4.0 rebuild after engine bay fire?
Strokermjcomanche replied to VorTekX's topic in MJ Tech: Modification and Repairs
https://comancheclub.com/topic/47985-project-code-red-88-olympic-edition/ -
I’m more or less just replaced everything that looked bad . If you had a donor vehicle I would say that would be the best way to do it. Just swap everything over at the same time. If you haven’t already please read my build thread . That may answer all the questions that you have, or at least some of them -
This engine was rebuilt 300 miles prior to an engine fire. When the fire department put it out they filled the cylinders with water, which in turn ruined the engine. So technically the fire didn’t create the engine having to be rebuilt, but putting the fire out did https://comancheclub.com/topic/47985-project-code-red-88-olympic-edition/ -
Made by crlaurence. I have all the paperwork for it at my house when I get home in a couple weeks.
Johnr iirc ?
Looks like your ratio of door keys to ignition keys is less. I do have more door keys if you’re looking for some.
Replacement headliner fabric
Strokermjcomanche replied to Anthi4078's topic in MJ Tech: Modification and Repairs
Have you tried going to your local upholstery shop? Although some shops may not sell you the material they may know where to get it local. Otherwise some of the better shops will order it in for you -
Neighbors 2016 Trax
Strokermjcomanche replied to Strokermjcomanche's topic in Member Projects: Other Cool Stuff
Stripped wheel bearing bolts
You need to use a 1/2 inch 12 point socket. -
https://merced.craigslist.org/rvs/d/lee-vining-jeep-4x4-rv-motorhome/7565812310.html
I think I can confirm, no more walker shortbed pipes.
Strokermjcomanche replied to m2bandit's topic in The Pub
I had the local exhaust shop bend me up Some spares out of stainless, I believe it was 304. He’s a real cool Guy that’s cousins with my former boss. Not sure how logistics would work out but if anybody was serious I’m sure he could bend some more up for me. I still have one spare that he can use as a template. He made it a little bit longer where the tail pipe exits, which can be cut to whatever length you desire. Normally he uses steel hangers, in my case he used stainless hangers, but That is an additional cost
