Strokermjcomanche
    6
  1. Bought a 2001 Cherokee several months ago with no engine as it was a donor for another Jeep. The engine he swapped over ran fine in the Jeep before hand according to him, as he also took some body parts for the Cherokee he was repairing. I had an engine with 71,000 miles on it that I put in along with new injectors, new O2 sensors by Bosch, new wires, K suspension viper coil mod, New cam positioning sensor Mopar CPS…Pretty much everything new being that I didn’t have anything to work with beforehand. The wiring harness and ECU are original to the Jeep. Engine has a miss at idle , Swapped out everything all over again with no change, I am not getting any codes either. Swapped out for another ECU with no change, ran a compression test and one cylinder was a little bit low. So after doing Everything I thought that I could do I swapped another engine in with 22,000 miles on it and I still have the same issue. Any ideas or else I can look for a known problem.? I doubt two engines would have the same issue and this one has even compression throughout the all cylinders. I can take a video of it too and upload it.Thanks in advance
  2. Gjeep has, he just did a write up on here a month or 2 ago
  3. I normally leave one lug nut on And use a sledgehammer from behind the wheel knocking it outward . I used to work at a junkyard and never had one that I couldn’t get off. I understand that You said you used a sledge hammer... heat around the lip of the wheel first and then give it some big shots. You might bend in the lip of the rim but wheels are easily had .
  4. Engine installed and running . Also painted and installed fenders / header panel , bumpers / flares / grille/ yet to be installed but are painted.
  5. Absolutely not. I just can’t fathom why they took this apart to use as a donor.I probably would’ve never gotten at this cheap though
  6. Pulled the carpet to clean it and the floors are in good shape. Also put down A coat of rust seal and fluid film to protect it in the future. Installed the four-wheel-drive shifter and pivot point for the linkage while the carpet was out as well.
  7. 71k mile engine out of a 97 Xj cleaned up and installed along with a 91k mile aw4 . New water pump , thermostat, alternator , Transmission lines , DEI heat protectant, new fuel injectors . $800 of exhaust parts installed too . New converters (3) , new o2 sensors, gaskets , muffler / tailpipe. Also installed a 0630 to 0331 exhaust adapter and will be using a k suspension kit with a viper coil to eliminate the ignition rail
  8. Engine compartment cleaned up
  9. I sure hope so, can’t wait to get it done
  10. No , not that big of plans lol. I plan on leaving it 2wd and installing the engine I picked up last year along with a sprintex supercharger. I don’t plan on driving It in the winter , just too clean . I was going to use it in my other Cherokee I purchased years ago , but I have a 22k mile engine to install if that one ever fails .
  11. Picked this 2000 up today . I do have some big plans for this one , but I have to finish 2 other projects before I can even consider doing this one . I’m the second owner , this came up from South Carolina last year .
  12. They are reversed / mirror image of each other
  13. I have a 97xj motor /trans/tcase that has only 75k on it . I’m wanting to see what all I need to install it in my 01 that I just bought . I already purchased the parts for the viper coil modification but I’d rather not use the 00/01 exhaust manifolds and precats if possible. Can I just use a 98/99 ecu and the 98/99 engine harness so I can only have the 2 o2 sensors and one catalytic converter? Is there a legality issue ? We don’t have emissions testing around my location thanks in advance.
  14. No more squatting, new leaf springs helped out a lot. Also hung couple fenders and got a Hood in the same color.
  15. Yeah possibly. Came from Kentucky, I don’t know if he was the second third or fifth owner lol.
  16. It’s Probably the Switch/sensor on the proportioning valve triggering the light. I think there’s a procedure to make the light go off ( that’s if you do have enough brake pressure) . Simone else can chime in on that ..
  17. Did you grind/file down where the pushrod makes contact with the switch?
  18. 2wd 163k miles , decent paint / body , no engine. The person I bought it from took the engine/ header panel / fenders / bumpers and hatch and used them on his girlfriend’s RHD Xj that had a rod knock . Only rust issue is the driver rocker panel. What am I going to do with it ? I have no idea lol . One idea is replace the body panels he swapped out and throw just an engine in and keep it 2wd , or convert to 4wd while doing the engine.
  19. There are a couple mopar TPS on eBay , I believe the numbers are 33004650
  20. Four bolts and the bumper is off. Even if the bolts break they are easily replaceable. Then you don’t have the risk of over spray. But if you want to paint with the bumper on .. sliding several pieces of cardboard around the bumper ends and taking the tailgate off will allow you to spray it on while on the vehicle
