6
I agree, tried explaining to him that you can’t find these parts. I have spares, but it’s still not the point. I know people want me to sell some stuff, but that’s why I won’t. It’s never the front end it gets damaged it’s always stuff but you can’t find easily
Thank you , it was a dent/ rust free bumper . Now it’s a rust free semi straight bumper
Definitely not 100% by any means. This will get me through to next year , I have a bed I got off of Pete last year that I’m going to put on Next summer and I’ll fix the bumper better next year when I have it off
Sad as it sounds, I’d rather have the tail light broken. But yes it came unscathed.
Yep , That’s correct. Seems like the people you help the most screw you the worst .
I don’t know if he has two pennies to rub together. I don’t think he realizes how much it’s gonna cost to do it correctly. I’ve been able to straighten out some bumpers in the past , but why should I help him out After the way he treated me? Probably gonna tell him to either find me a bumper or give me $800. But I doubt that’s gonna get me anywhere
it got the corner of the bed pretty decent. I have another bed, still not the point obviously. The bed was in good enough shape that I could’ve sold it or kept it for another project, now it’s more work if I want to fix it. Sad part is I never wreck any of my stuff it’s always somebody else that does It has nothing to do with me. It’s always somebody else doing the damage. And I cut his yard and seven other yards on my street for free, and this is how I get repaid.
It should be, unfortunately it wasn’t evident to him. I tried explaining to him how hard it is to find good rust free bumpers and it went in one ear and out the other. And then to top it off you start to get mad at me. Whatever happened to excepting blame? Yeah unfortunately the road only goes one way lol
Was parked in front of my house, neighbor backed up into it. He couldn’t understand why I was upset. And then started getting mad at me because I was upset. Accidents happen, I get it. Man pay attention though.
what bolts into this hole
Strokermjcomanche replied to Aussiemj's topic in MJ Tech: Modification and Repairs
I really don’t think anything on that, but if you have a plow I’m pretty sure it uses that hole. -
Alignment Brainteaser
Strokermjcomanche replied to eaglescout526's topic in MJ Tech: Modification and Repairs
I would get yourself a adjustable lower ball joint. Not only will you fix your camber(which is what I believe needs to be done), it will also fix the caster at the same time If adjusted properly -
I used “leather Refresh “ on mine and it’s held up really well . Those look great by the way
Removable Drain plugs?
Strokermjcomanche replied to KoopaKid's topic in MJ Tech: Modification and Repairs
There are drain plugs in the factory floorboards -
AW4 Speed Sensor?
Strokermjcomanche replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
AW4 Speed Sensor?
It’s on the drivers side of the transmission behind the 4wd shifter linkage pivot bracket that mounts to the transmission and tcase . I’ve had a couple jeeps over the years that didn’t shift correct. Normally the fix for mine was replaced on the throttle positioning sensor or the detent cable -
ISO cylinder head
Strokermjcomanche replied to Strokermjcomanche's topic in MJ Tech: Modification and Repairs
Thanks to everyone that replied. Some issues came up and I’m not doing anything with this right now, as a matter fact not doing anything right now. Again thanks -
I understand that this should/ might also be in wanted. I’m looking for a 0630 or 7120 head , Just as long as it has the Threaded sensor hole at the rear of the head . It doesn’t need to be anything real special, just something I don’t have to worry about for years to come. I had mine rebuilt several years ago along with the block being machined and it only cost me $500, now any reputable head is $500 + . Just seeing if somebody had another idea out there that might be cheaper and good . The local machinist is about three or four weeks out, and I’m not gonna have that much time to get this done . Not to mention I don’t have a used cylinder head to be rebuilt in the first place. The engine didn’t come with the head. Thanks in advance everyone.
3rd Party Header Panels
Strokermjcomanche replied to acfortier's topic in MJ Tech: Modification and Repairs
X2 -
Header Panel Studs
Yes , One washer on each side of the fender. Then you put the nut CERT insert through the washers and it’ll squeeze everything together. -
Header Panel Studs
Use washers if the hole is too big -
Header Panel Studs
Factory jack handle clip alternative
Strokermjcomanche replied to schardein's topic in MJ Tech: DIY Projects and Write-Ups
You just pinch that tighter so it would grabYou just pinch that tighter so it would grab -
