You can get an axle out of any 2wd MJ or XJ.....with all the upgrades to 4x4 on this site someone should have one out there.
A load scale like mentioned above might give you a rough idea but if you want to dial it in you need to find your local dirt track and talk to some of the guys running super stock or open wheeled modified. They will have a set of scales (one goes under each wheel) that will allow you to dial it is right were you want it.
While you are there take a look at the suspension set ups and ask some questions on how they set up the cars......some guys come up with some very unique ways of tuning the suspensions so that you get the power to the track were you want it.
It is called a G80
Found in their turbo cars.......if you could find a turbo Volvo wagon it would probably have it......I will see if i can find years and models
I think you would have to remove the tank and install the whole take and pump together.....then somehow you have to get a trigger to turn the pump on and off.... :hmm: ...I think the pump will supply more fuel than the carb needs..... :hmm: .......
You don't have an old SB Chevy kicken around? I think that Mech pump is the same
I have had it in a TJ, XJ, and an MJ....It does not have all the power of the HO 4L.....but for a daily driver you can't beat the mileage..... :thumbsup:
Your Chain is stretched....That is the "POP".....The reason you do not notice on dry pavement is that all the tires are rotating at the same speed so there is no stress on the chain....In the mud the rear tires have power and spin....the front want to spin but can't because POP the chain jumps off the cog.
. :MJ 1: .
Chains are easy to change....search the site there is a nice write up with pics..... :thumbsup:
Get a relay mount it under the hood Wire it like this.....Run # 86 Through the switch to an accessory on your fuse box...That way they turn off with the Key
Do you see bubbles rising up in the reservoir when you push the pedal down?
If so it is either that #11 has collapsed or #9 has worn out
You probably need to work on your master......you can pick on up and install it easy........
If you are interested here is a link on how to fix it if it is the #11 spring that has collapsed... :thumbsup:
http://comancheclub.com/topic/41742-clutch-master-rebuild-mod/
2 Quick tests have a partner help press the pedal
1) Take off the top of the master and press down on the pedal.....if the fluid goes up or bubbles it is your master. (is there leaking in the cab were the master is located?)
2) Same thing but look below.... is fluid leaking?.....from the line or the bell housing
That will narrow it down to upper or lower and you can go from there. :thumbsup:
I would be interested in an educated answer myself.
Experience taught me the only advantage (that I can see) is that if you pull a Renix motor it limits the amount of harness you have to undo.... :dunno: ...I do not know if that was the intended purpose.
