yxmj
    3
Everything posted by yxmj
  1. yxmj
    MJ drag race
    I wish you could see the time/speed sign at the end of the track
  2. Look at my avatar That is 31's with stock rear springs and an 1.5" spacer in the front You could try something as easy as this... https://teraflex.com/shop_items/xj-cherokee-2-budget-boost
  3. I am fortunate that my kids are high-tech enough to "fracture" the law and have the skills to download off the inter web I have every Python movie made as well as every special and live performance. This also includes every TV episode........all in "High def" (for the time) Fun fact.....did you know that they did 2 complete seasons of the TV shows totally in German...... same sketches same cast ....they all fluently speak German
  4. If it helps the Model # is P05187085AG
  5. I think I have a short in my harness I can obviously see the wire colors and find the pin out for each sensor I want the ECM(PCM) pinout so I can trouble shoot it without removing the harness yet. By all means if Jay has access to a pdf I am game Below is one I have for a YJ I found a similar (not on this computer) one for my 2002 Dakota 4.7 If I have a drawing like this I could rebuild a harness if need be
  6. I think that the 05 is from the same generation so it might be close.....I will have to look at the manual Thanks Pete!
  7. Do you have a link for a pin out?
  8. yxmj
    Dogs!
    Indiana Jones......Olde English Bulldogge Here she is 1 year......I taught her to wave
  9. I have been trying to find a pin out of the ecm/pcm for a : 2008 Dodge Dakota 2wd 3.7 6 speed standard But have been unable to find one.........I easily found one for my 2002 Dakota..... but the 2008 seems to be a white whale. Is there anyone who has a link to any site that would have any info?
  10. It will be fine and it will tell you right away if the problem is the battery or the alt.....no guessing
  11. What happens if......You get it running.....you remove a battery cable from the battery......does it continue to run or die?
  12. They did at least tied here down with...........a piece of string
  13. A wrangler pcm (YJ) will work (with some tweaking) ( you can use one for both 2,5 and 4.0......Just leave off injector 5 and 6 if you have a 2.5) you might have to get the correct CPS
  14. Vice grips you will have it out is less time that it takes to read this reply
  15. First it would be easier to answer if you were more specific as to what is rotted out. I would guess it is in the rear from the shock towers back? As above a YJ frame will not fit..... but (because the YJ frames were bad for rotting out) there is a Large after market of ready to use frame splices and re-enforcing pieces. https://www.amazon.com/jeep-yj-frame-repair-kit/s?k=jeep+yj+frame+repair+kit A little time and effort and you would easily have a ride worth more than $1000
  16. yxmj
    GM Vin Search
    I have had incredible luck searching Jeep vins......Dodge Vins......Ford vins Usually a quick search a couple of clicks .....enter the vin and I can print out a free build sheet no problem. Has anybody had any luck with GM/Chevy trucks? All info says call a dealer they can do it.....NO.....Dealer tried then gave me the number to GM customer service, who tried unsuccessfully to guide me then finally said I had to send an email for info....just got the reply......Sorry info is not available Truck is a 1998 Chevy......anyone have a lead on a site?
  17. yxmj
    wood stoves
    Pete you need to look into one of these..... https://www.amazon.com/VODA-4-Blade-Fireplace-Increases-Friendly/dp/B01CD2AIV8/ref=sr_1_1_sspa?crid=38WLBZEZ8QMOV&dchild=1&keywords=heat+activated+fans+for+woodstoves&qid=1610488244&sprefix=heat+activated+fan%2Caps%2C205&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExVUgxT0c5T1BEMEhNJmVuY3J5cHRlZElkPUEwMTE2ODU0MU1MSFVaR1hSWlJGSCZlbmNyeXB0ZWRBZElkPUEwODQwMDYzMlhJTVJFTlE0UEZOJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== I (we) have been using wood for 50 years fireplaces....stoves ....as well as external boilers.... #1 secret to maximizing the BTU out of your wood is to circulate the air......
  18. Color coded diagram below Connect them correctly and see if you still have a problem
  19. Is there not a hex screw on the "top side"?
  20. A little Gorilla tape and some tranny fluid and your good to go
  21. So many questions........why is the first........second would be .....speed bumps?
  22. I don't see any reason you could not peen that flat and use it. It is basically acting like a heavy duty dust cover
  23. Maybe this is on here already, but I thought it might help for those who want to change to open cooling easy 2000-2004 Dakota’s /Durango’s have the right filler neck for a quick and easy install. Do the heater valve delete and you could use you coolant bottle for a reservoir…… Dorman and others make after market as well
  24. I have on on a trailer as well I changed the hand winch to a 12 volt winch so when i go on part runs i can drag the diffs out of the bush then onto the trailer by myself.....don't know why the pic is blurry
  25. Just to clarify ...... not looking to identify gear ratios...... Looking for info to identifying posi (trac lock) by id tags or stickers only
