Here is an easy mod to help any Jeep breath better.
Having Yj’s Xj’s and now my first Mj, I have always wondered about the air box set up (used on both the 2.5 as well as the 4.0). Take a look at your air filter….it is +/- 13” x 6” or 78 inch² of breathable surface. Now take a look at the “Air intake hole it is +/- 4” x 4” or 16 inch² ( a little less that 1/5 the size of the filter)………Come on…….Lets let this thing have some air!!!!!
Here is my quick mod.
Years ago I worked at a plant that fabricated and assembled large farm equipment, One of the things we built was the grill that covered the rad on large tractors and earth moving equipment. This grill was made out of a thin gauge steel sheet perforated with holes, the slang name for it was 50% (I guess because half of the surface area was holes) So to make the grill we would run a sheet of this material through a “corrugator” so that it got a tight curving wave (like corrugated cardboard or roofing) The Idea being is that if you had a hole 1’ x1’ to cover and you took a piece of 50% 1’ x 2’ corrugated it down to 1’x1’ you have the protection of the steel grate but because you have equaled the surface area for all intensive purposes you have not restricted the air flow……Make sense??
Anyway enough rambling…..year ago I had picked as much of the 50% out of the scrap pile as I could and set it on the shelf hoping someday I would find a use for it…..Here it is
I use K&N in all my Jeeps……Find or fabricate a perforated piece of steel as seen in my picture ( The smaller the holes the better…..and every hole is going to ad air flow.) Try scrap yards or old implement dealers??
Remove the air box and cut out as much of the side against the fender as you like (remember trying to get cool air so my thinking is that fender side is cooler than motor side) Cut and fasten your (rivet / screw /or even silicon) your mesh in place, maybe a fast shot of paint to make it look “factory” and reinstall the box.
Just a cheap easy mod that you can do (in less time than it took to read this :laughin: ) it helps with the airflow, but still gives protection and a stock look.
You can see in the picture…..I could go bigger yet…..but I easily doubled my available intake air. :thumbsup:
