Krome_Dome
Krome_Dome's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. Thank you for your input! I hadn't considered that.
  2. Yes it is a front sump. You think i'll have clearance issues? I plan on getting a 2wd beam axle. I plan on doing a full custom dash setup. I like things to look uniform and not all hodgepodged together. Lol I just want to get her running first though.
  3. If I can I will use the obd2 adapter and the torque app until I can install real gauges. It will likely end up being a custom dash lol.
  4. Oh my god. I originally wanted to swap an alh tdi in manche and give her a little lift. Then I got new influences and an sr20 lol.
  5. Thanks man! I appreciate that. I'm pretty stoked. I'm hoping it will be done by mid summer.
  6. I gave that a try. Everything's 200+ miles away from me. Lol. Appreciate it though.
  7. Alrighty, thanks man. That helps a ton!
  8. I think i'll be going with an 8.8 then! Did any of the 8.8's come with the lsd, and how do you tell if the axle has it? I'd rather not buy an aftermarket one if i don't have too.
  9. I haven't done too much research on rear ends but if a Ford 9 inch will fit (width wise) I'd like to go with that. Do you have any suggestions?
  10. I have a Nissan unit.
  11. Thanks man! I already have a 5 speed tranny I purchased with it. It;s about 90% complete. All I need is a lower harness, front mount, external wastegate, a bov, and a few other things I can't remember off the top of my head. lol. Custom mounts and driveshaft too lol.
  12. Nevermind I got it. Thank you!
  13. Hey guys, so I'm going to be doing a swap and figured i'd post my build for anybody who wants to follow along. A little background: I bought an '86 Jeep comanche 4x4 5 speed with the 2.8 v6. Yes, the v6 was terrible, lol. She's about 95% rust free. I did a burnout a few weeks ago and I thought I blew up the transmission, turns out the diff just blew up. So naturally I bought a new engine for my truck. (When I thought it was the transmission.) I figured if I'm gonna pull the engine and tranny again I'm swapping in something better. I purchased an SR20DET. It is a 4 cylinder turbo charged Nissan motor out of a Nissan S14. Basically its a 240SX. My buddy and I originally built it for his Nissan D21 Hardbody but, he wanted a running project so I bought for the GBD. (Good buddy discount.) Here are some photos of the engine and turbo! Ignore my face. The engine just needs a valve cover gasket, new cam lobe bolts, and it needs timed. She should be ready for mounts after that. I plan on taking the truck from 4x4 to 2wd and turning it into a track/auto cross truck. Yeah it's a bit sacrilegious, I know but, I want something different. Everybody lifts there jeep and has a 4.0, 4bt, om617, or some variant of a v8 in it. I was originally gonna throw a 5.0 in it but came across a killer deal on this engine. Alas, I have begun tearing the truck apart, which took longer than i'd like to admit. This is my first engine swap, really any major mechanical work at all. I've done standard maintenance and a clutch in the past but thats about it. So this will likely be a roller coaster. I'll keep you guys updated! Anybody who is looking to work on their jeep, at least the 2.8, you will need a set of metric tools. I don't think I used any standard accept to get the air filter cover off. The transmission drain bolt was a 24mm and you will need an 18mm. Chances are your set doesn't have those. I haven't seen many sets at all with an 18mm. Other than that it's just your typical 10-15mm nuts and bolts. If y'all have questions feel free to ask! I am dubbing her SRMJ.
  14. I tried that with facebook, that clearly doesn't work. Lol
  15. This might sound retarded, but I, for the life of me, can not figure out how to post a picture. How in the hell do I post a photo to my topic? I'm trying to write a build thread and I can not figure it out.
