comanchebuilder21
2 Followers
    antioch,il
  • Interests
    Comanche!!
comanchebuilder21's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. This axle was swapped in so would I be better off buying a used axle with better gears or buying a set
  2. How much would a regearing kit for a d44 go for that's what's under the truck now that I drive with 3.73
  3. I had the b/a in my 89 an thing was junk an I shattered it so now I'm running a ax15 an I'm pretty sure it's same as the one in the other.ill take a photo of it an different cover so we can fully figure out what they changed
  4. It's not the b\a 10 trans I have one of those for my 89 an I know it's not that. I put 35s up on my truck an I'm just not liking the drive so was trying to see if I axle swapped with my other. If I could get a better ratio but I have 3.73 right now an looking for 4.10 or 4.88. I check what axle is under it tomrow it's a soon to be project truck if I ever get time so haven't really touched it since bought
  5. It's a 88 4.0 5 speed not sure exactly on what Trans think ax15 maybe
  6. What is the gear ratio I've came up with 3 diffrent ones from 3 diffrent sources 4.10 4.56 an 4.88 I belive I just want stock ratio.i believe it is the amc20 axle
  7. Lol srry it double posted so I was trying to delete this one
  8. Yes they were torqued properly that's what's confusing me
  9. Plz comment on this one don't know why it made 2
  10. So just put a ax15 back in to my mj 2 weeks ago everything got torqued properly an all was fine till today. Started it drove for like 2 miles then when I'd press the clutch it'd make a terrible grinding screeching sound. So I get under it every bolt holding Trans to block was 1/4 OF THE WAY UNDONE. Any ideas wtf is going on. I tightened it back up an it's good now. This confuses me
  11. Not sure on measurements need it tomrow if someone is near three rivers michigan.
  12. Going to once I put Trans back in just wanted to see if anyone's tried it or knew
  13. Hmm that's to much lift on a comanche. Atleast for me
