comanchebuilder21
Everything posted by comanchebuilder21
It's not the b\a 10 trans I have one of those for my 89 an I know it's not that. I put 35s up on my truck an I'm just not liking the drive so was trying to see if I axle swapped with my other. If I could get a better ratio but I have 3.73 right now an looking for 4.10 or 4.88. I check what axle is under it tomrow it's a soon to be project truck if I ever get time so haven't really touched it since bought
So just put a ax15 back in to my mj 2 weeks ago everything got torqued properly an all was fine till today. Started it drove for like 2 miles then when I'd press the clutch it'd make a terrible grinding screeching sound. So I get under it every bolt holding Trans to block was 1/4 OF THE WAY UNDONE. Any ideas wtf is going on. I tightened it back up an it's good now. This confuses me
Not sure on measurements need it tomrow if someone is near three rivers michigan.
drive shaft question
comanchebuilder21 replied to comanchebuilder21's topic in MJ Tech: Modification and Repairs
Going to once I put Trans back in just wanted to see if anyone's tried it or knew -
Hmm that's to much lift on a comanche. Atleast for me -
So will adding more lift work -
I have a short bed with 5.5inch lift on 38s atm I have a drives haft from a long bed I know the splines match but will the length fit?
Need within 30-45 minutes of three rivers,mi txt 224 656 3114 I don't need expense but I don't want garbage send me pic an price
- transmission
- jeep
(and 4 more)
Tagged with:
Transmission Help Please
OK thnx so much for the help -
Its external -
How can I tell internal / external? I'm really bad with transmissions -
Both 6 cylinders -
Is there any other parts ill need? An thnx for the help -
I have a 89 Comanche an I got a free Jeep trans from a friend but the shaft that slides into pilot bearing.in back of engine is 3/4 instead of the 1/2 anyone got a part number for the 3/4 bearing or link?
