comanchebuilder21
Everything posted by comanchebuilder21
  1. So since my pilot tip is 3/4 i called around for the bigger pilot bearing but no one can find it anyone got a link for one
  2. So do i need bigger clutch now to fit the tip or is there simpler method. Srry should of specified year of the ax
  3. That makes sense the ax 15 i got i believe is between 92-94
  4. Well the input shaft is thicker on the ax then the ba/10 and it won't slide in al the way
  5. Ya i have a extra ax15 but i need a diffrent clutch to make it fit
  6. I got a 5spd peugeot trans and the adapter housing between the trans and t case a bearing broke i need help locating part numbers or size of bearing cause mine was destroyed pictures of bearing would help to
  7. Please.send me pics or call needs to be. Within 5 hours of Antioch,il
  8. OK so I know nothing bout t cases can anyone tell me what model it is its from my 88
  9. kicking it with my girl
  10. Well I think it'll look sick and its a challenge I wanna do I'm Gonna work out all the specs I just wanted to see what peoples opinions. Are on it
  11. So I had an idea of putting duallys in front and rear of a Comanche.and.wanted to see way ppl thought before I do it so let me know
  12. kicking it with my girl . pizza time!!!
  13. Ya my front shaft always spins but. It was perfectly lubricated it still is but hey I got some good insight. Thanks guys. I'm gonna put my spare in till I order a performance. One
  14. Ya all mounts were perfect intact guess ill try an weld it up and hope thanks for the insight
  15. This t case has less then 5k on it and has not been mudded or anyway.offroaded since. Got t case in I messed with it a little and it seems if I put it back together. And weld it up it'd be perfect again Cause the insides were perfect no damage or even shavings
  16. 2wd. But it destroyed the 4wd side
  17. Ill set the pic as my profile and I was just doing about 50 when happened
  18. blew up my t case in my 89
  19. blew up my t case in my 89
  20. https://picasaweb.google.com/m/viewer#photo/108793388754203896000/5808556949214277569/5808556948550909426
  21. Blew up my t case ripped it in 2. Trying to put. Pic up can anyone tell me how need some insight on how it might have happened once you see pic
  22. My t case exploded out of the housing today for my 88 so I'm looking for a cheap perfectly working one. To get me by for couple months
