Crist Clapper
    Blair County PA
  • Interests
    SJ Grand-Wagoneers & XJ Wagoneers
Crist Clapper's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. Does the 82300393 have a clock?
  2. What I learned: The gauge-needle is moved by magnets driven by 1-ohm to 88-ohm(full-tank). Applied voltage... Watch the needle go ♬ up-and-down, up-and-down ♬. Cleaned terminals on sending-unit and applied dielectric-compound. All is good in Désirée land again!
  3. Poked around a bit today... No progress. Trip to the local mechanic for help.
  4. I have the FSM wiring diagram... Doesn't help me... Technically challenged! :doh:
  5. Any chance someone could connect the "LETTERS" for me?
  6. Updating the obvious... Tank levels not a factor! :thumbsup:
  7. Disclaimer: I'm not technical. What are the most common reasons a gas-gauge does not work?
  8. I have the clock working... That was the easy part! Then there appears to be a connector that may interface with the magic-blue-box. But I'd rather do some testing before making any connections. Anyone happen to have a wiring diagram for it? Such as a Chilton or Haynes?
  9. I kinda get the feeling that the challenge may too much for me. But... At maybe at least... I won't have a blank-cover! ;)
  10. I know... The NOS display didn't come with the associated wiring/controller. I'll won't tell anyone if you don't! :P I thought you only went for NOS on your FSJ's Crist. :yes: I used to browse IFSJA all the time and read through countless threads. Methinks I should scour the web for good deals on rare goodies like these.
  11. MAYBE someday I'll get mine to work... No promises! I found two used complete units and one NOS display-module.
