3
I know this may be off topic, and that the OP is looking to match 97 plus to the rear, but here's some pics I stole from somewhere of a guy who did a set off of a Chevy pickup.... modern looking and may be able make work with the 97 plus style.... just my 2 cents.
The sight of the snow like that makes me miss living in Michigan. Its a rarity like that where I'm at now. Enjoy it!
Welcome. If you don't know what CPS is, it is the crankshaft position sensor, and is a common failure point considering failure to start sometimes. It mounts on the transmission bellhousing near the top on the driver side. If the trans was replaced, and the shop did not remove this, they may have damaged it... get a new one either from a dealer or wherever else. It has been told that the dealer has discontinued these, but some are still available. I'm a Jeep dealer tech, and for your truck, I do not beleive that going to the dealer for a computer scan will help you at all. Most dealers anymore no longer have the correct cables to plug into your truck, and on top of that, the Renix system doesnt keep memory, so codes do not get stored if a problem arises. As was said, working with us and with a multimeter, you can figure out whatever you need on this system. It also sounds like you are doing a lot of possibly unnecessary work. There arent that many relays to go through involving engine running, but it is possible that with age some of them are corroded and not working properly. I ran into this on my boss's MJ... the AC relay was corroded inside and would no longer make good contact making his AC not work... easy fix, but took a while to figure out. Many things on the MJ are like that, just be patient, and ask for help. Another thing that could cause running issues is the oxygen sensor. Its also an easy fix and was reccomended by the factory to be replaced every so often for good running. On many of the trucks the factory mounted a timer under the dash to make a light come on at a predetermined time or milage to make you replace the o2 sensor. Its relatively cheap and can make a huge difference in the way your truck runs. Age and milage will also be a factor in the fuel injectors. If you get to the point of replacing those, ask around first, as there are some upgrades that can be done here for the same price or less as new injectors. Running some fuel system cleaner through can't hurt anything either. Good luck and feel free to keep asking any and all questions that may come up.
Why is is when anybody mentions a swap, with a motor they have available to them, somebody always says to put a 350 in it???? Yes maybe adapter parts are more readilly available, but thats not the point or the original posters question. I think Advance adapters has a kit for the 302, but you would have to look it up to be sure. If an adapter is available, then an AX15 or NV3500 setup from an XJ would be best as you wouldnt have to worry about making them fit. Making the electrics work with the Jeep will be the hard part. You may be able to find more info on a swap like this on www.greatlakes4x4.com . They are much bigger sites with a much broader range of info on topics like this that are a little out of the ordinary for our sweet little home, comancheclub. Good luck, and let us know what you end up doing!
Your biggest issue with the selectrac out of the 84 will be all the vacuum hoses and routing them all correctly. The NP228 has a butload of vac hoses to deal with, along with the sliding lever actuator. Youll either need to take very carefull notes as to routing of these hoses when you take it apart, or find a good diagram so you can put it all back together correctly when the swap is finished. And like was said, both these vehicles may have the same axle gearing, so that might save you from having to weld new perches on the 84 XJ rear axle. Confirm what the gears are in both vehicles and go from there. Good luck.
Buying a comanche tomorrow/ dw questions
dasbulliwagen replied to conner's topic in MJ Tech: Modification and Repairs
If it was lifted and didnt have a proper front end alignment, the wheels will toed in, which could cause death wobble, and the caster angle probably wasnt changed as that can make death wobble start easilly if there are any other factors like bad toe, or wheel imbalance to set it off. Also, if it doesnt have an adjustable track bar, the axle will be shifted over to one side... a sure sign of a cheap out lift! Get it home and we can help you straighten this thing out! Good luck. -
The front XJ lift and steering items will work for your MJ. The rear add a leafs for an XJ if added to the MJ packs probably won't get you much if any lift, as MJ springs already have more arch in them than XJ leafs do. If added to the stock MJ packs spring under, it may actually lower the rear end due to the added leaf thickness. I think the other guy was saying that if you are keeping the 4 cyl the trans and tcase in the XJ won't be any use to you, unless you swap it all over completely from the XJ to do a 6cyl swap, but I'm not sure that that is the info you were looking for.
I think I have the same truck you do, 87 2.5. Ive swapped to 4:10 gears and have yet to put in the 5 speed. Engine RPM is increased in 4th gear, but after looking at one of the tire size and gear calculators on the site here somewhere, I found that if I kept the 4 speed with the 4:10 gears, and went with 31 or 32 inch tires, I would be VERY close, especially with 32 inch tires, to factory top speed RPMs. A fifth gear in that situation would be all but worthless, especially with the 2.5.
I looked at doing this to my donor trans and gave up before ruining it, if I need to remove the handle, Ill pull the whole thing and cover the hole with a rag. Not worth screwing something up.
The livingroom in my house is a converted carport, and it came with a natural gas radiant wall unit. We used it a couple times and combined with a ceiling fan it heated the 600 sq ft room nicely. A propane unit should do the same. Just make sure you use a fan with it to circulate the heat better.
EGR valve/tube/switch Elimination??
dasbulliwagen replied to skidoo_j's topic in MJ Tech: Modification and Repairs
What header are you using on your 2.5? I don't yet know what header I will be using on my 2.5. I just know that the only ones now available are for later non EGR models for YJ's and TJ's. I just figured Id try to make one of those work and re do my exhaust to get to get to the header outlet.... no big deal, I don't think. But then again, I havent done it yet! -
Doing what you are proposing should be fine. I plan on doing the same thing when I put a header on my 87 2.5. -
86' XLS Comanche Questions
dasbulliwagen replied to Comanche County's topic in MJ Tech: Modification and Repairs
This gives me hope that the 86 Waggy I had given to me has 4:10 axles under it. It has the 2.8, A904, NP228 combo in it, but I couldnt read the axle tags. With the NP228, that means it has a non-disco front axle! -
If its rust free, you may be able to get under and see if it has the axle tags on it still to get a gear ratio. But I would assume it might have 3:73 or 4:10 gearing. I don't think any of the 86 options included a 3:55, except maybe a 4 speed 4 cylinder. Check this out and let us know what you find! -
I should hit 350,000 next year, and plan on keeping a camera with me to document it!
I assume youre talking about the belt at the compressor. Where are you applying oil to? If youre applying oil to the clutch discs, youre probably screwed at this point. The compressor clutch needs to stay clean and dry from oily residues. Some places do just sell a clutch kit for the compressor, but it will usually cost as much as a complete compressor will or real close to it. You may try just tightening your drive belt as well. I had a similar issue and tightening the belt took care of the noise. Ive also seen them make noise because the belt was old and glazed... just needs a new belt at that point. Good luck.
I have my truck ready for this, but I know that the mirrors don't work right so I havent wired up the switch yet. Maybe if I find good working donors later Ill tackle the wiring.
manual brakes/ 99-04 WJ booster upgrade
dasbulliwagen replied to Boots's topic in MJ Tech: Modification and Repairs
Not wanting to change to a dual diaphragm because of added weight is ridiculous. I'm not trying to sound mean, but in the grand scheme of things, the little (if any) added weight problem is greatly outweighed by the increase in braking performance. If you need to change it, make it better while youre at it. My 2 cents. -
Hey Guys Who Knows How To Search VIN?
dasbulliwagen replied to Jeep Driver's topic in MJ Tech: Modification and Repairs
Please be aware not all the option descriptions below are accurate as chrysler has recycled some of the codes for newer options. Enjoy. Vehicle Service Information Year/Model: 1989 JEEP WAGONEER LIMITED Last Odometer: 0 Miles on Body Style: XJNX74 In-Service Date: September 29, 1989 Engine: ERB-DESCRIPTION NOT AVAILABLE In-Service Odometer: 0 Miles Transmission: DGS-4-Speed Automatic AW4 Transmission Odometer Type: Miles Color 1: PQ9-DESCRIPTION NOT AVAILABLE Car Line: W Color 2: QQ9-DESCRIPTION NOT AVAILABLE Build Date: February 7, 1989 Current Market Register: U Hour: 15 Vehicle Sale Information Selling Dealer: 23828 - DON HILL JEEP EAGLE Sales Type: 1 - DIRECT RETAIL City: KINGSPORT State/Province: TN Country: USA Telephone: (423)246-4455 Standard Equipment Code Description Code Description Code Description APAS Monotone Paint BA1S DESCRIPTION NOT AVAILABLE BCYS DESCRIPTION NOT AVAILABLE BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CDBS Reclining Front Seats CKBS Floor Carpet CKVS MOPAR Third Row Cargo Bins w/Table CLES Front Rear Floor Mats CSAS Spare Tire Cover CSCS Cargo Compartment Cover CSRS Passenger Assist Handles CUFS Full Length Floor Console DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DHPS Selec-Trac Full Time 4WD System DHSS Floor Mount Automatic Shift Lever DJHS Dana M30/181MM Front Axle DMDS 3.55 Rear Axle Ratio GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GECS Front Left Side Sliding Window GEDS Tinted Rr Drs/Qtr/Liftgate Glass GFAS Rear Window Defroster GNAS Rear View Day/Night Mirror GNBS Driver Side Illuminated Sun Visor GTJS Power Mirrors GXMS Remote Keyless Entry HAAS Air Conditioning HGAS Hood Insulation JAAS Instrument Panel JAYS Instrument Cluster w/Tach JBGS Instrument Panel Woodgrain Bezel JCAS 85 MPH Primary Speedometer JGBS Digital Clock JHAS Var Intermittent Windshield Wipers JHBS Rear Window Wiper/Washer JJAS Cigar Lighter JKBS Inst Panel Mounted Hood Release JPAS Power Windows JPBS Power Locks JPTS Power Front Driver/Passenger Seats K3CS DESCRIPTION NOT AVAILABLE LAFS Key in Ign/Seat Belt Warning Buzzer LAGS Warning Chime LAKS Headlamps On Warning Chimes LBBS Courtesy Lamps LBCS Glove Box Lamp LBDS Ash Tray Lamp LBES Cigar Lighter LCDS Map/Dome Reading Lamps LDBS Cargo Compartment Lamp LDHS U/Hood, Removable/Rechargeable Lamp LHDS Headlamp Off Time Delay LMAS Halogen Headlamps LNJS Fog Lamps MB2S Bright/Black Front Bumper MB6S Bright/Black Rear Bumper MCAS Front Bumper Guards MCBS Rear Bumper Guards MFJS Heritage Grille MHBS Bright Windshield Moldings MJAS Bodyside Molded-In-Color Moldings MMBS Hood Stripe MMFS Day Light Opening Moldings MMJS DESCRIPTION NOT AVAILABLE MPAS MOPAR Chrome Front Applique MTBS 4.7L HO Badge MWAS Roof Rack NAAS Federal Emissions NBAS DESCRIPTION NOT AVAILABLE NBKS EVAP Control System NDAS Catalytic Converter NFAS 20 Gallon Fuel Tank NHMS Speed Control QQ9S DESCRIPTION NOT AVAILABLE SBAS Power Steering SCGS Leather Wrapped Steering Wheel SFCS Front Perf Tuned Shock Absorbers SGCS Rear Perf Tuned Shock Absorbers SUAS Tilt Steering Column TADS DESCRIPTION NOT AVAILABLE TBLS Inside Mounted Spare Tire WJNS 15 Aluminum Wheels XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z5AS GVW Rating - 4850# 1AAS U.S. Dealer Retail 161S Zone 61-Atlanta Optional Equipment Code Description Code Description Code Description *YL Leather Trimmed Bucket Seats -YY DESCRIPTION NOT AVAILABLE AHT Trailer Tow Group ARC Rubicon Group CACP Low Back Bucket Seats CKNP Cargo Compartment Carpet CKTP Cargo Tie Down Loops DGB All 4-Speed Automatic Transmissions DRMP Dana 35C/194MM Rear Axle DSA Trac-Lok Differential Rear Axle EAAC All Engines EAFC DESCRIPTION NOT AVAILABLE ERB DESCRIPTION NOT AVAILABLE GRJP Left Power Chrome Mirror GSJP Right Power Chrome Mirror GVBC All Vehicles W/Power Mirrors JRDP Power Driver Seat JREP Power 4-Way Driver Seat MDA Front License Plate Bracket NHBP Auxiliary Transmission Oil Cooler NMCP Heavy Duty Engine Cooling PQ9 DESCRIPTION NOT AVAILABLE RAAC All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCGP 6 Speakers RDCP Power Antenna TAAC All Tires TBB Full Size Spare Tire TPMA P205/55R16 BSW AS Touring Tires YGBA 1 Additional Gallons of Gas YGGA 9 Additional Gallons of Gas Z05P Rear Spring Group V Z59P Left Front Spring Group Ix Z78P Right Front Spring Group VIII 5AXA Polcastwheel Tracking -
Power steering fluid leak/cleanup?!?
dasbulliwagen replied to lexluthier72's topic in MJ Tech: Modification and Repairs
soak it in the engine degreaser, then go to the carwash and use the pressure washer to blow it all away. -
here's your build date, plus some more info. Looks like it was built and sold through the military in Switzerland.... never seen that before. And the original owner, lives (lived) in Punta Gorda, FL. Build Date: May 15, 1990 Hour: 21 Selling Dealer: 19997 - OMSC - RTE DE LA GLANE107 Sales Type: R - ROAD READY ONLY City: FRIBOURG SWITZERLAND State/Province: EX Country: SUI Telephone: (810)978-6564 Standard Equipment Code Description Code Description Code Description APAS Monotone Paint BAQS DESCRIPTION NOT AVAILABLE BCXS Nickel Metal Hydride Battery BGAS Power Front Disc/Rear Drum Brakes CSRS Passenger Assist Handles CUMS Mini Floor Console DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMFS 4.10 Rear Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror HCDS Heater w/Instrument Pnl Ventilation JCAS 85 MPH Primary Speedometer K3BS DESCRIPTION NOT AVAILABLE LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MMCS Rear Qtr Solid Window Insert MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF2S 18.5 Gallon Fuel Tank QB3S Intense Blue Pearl Coat SFAS Standard Duty Shock Absorbers SGAS Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AVS Export O.M.S.C. U.S. Specifications 105S Zone 05-Chrysler Military Sales Optional Equipment Code Description Code Description Code Description *X1 DESCRIPTION NOT AVAILABLE -SA DESCRIPTION NOT AVAILABLE ALM Liberty Jet Group ARL Kicker/SRT Livin' Loud Audio System CBAP Straight Back Bench Seat CKAP Carpets - Floor and Cargo Area DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission EPD DESCRIPTION NOT AVAILABLE GFDA Rear Sliding Window GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZA Manual Remote Mirrors JAY Instrument Cluster w/Tach JGBP Digital Clock JHAA Var Intermittent Windshield Wipers JJAP Cigar Lighter KKEP DESCRIPTION NOT AVAILABLE K2XP DESCRIPTION NOT AVAILABLE MBJP Black Front Bumper MDAP Front License Plate Bracket MFGP Body Color Headlamp Bezels MHAP Black Windshield Moldings MMKP Body Color Drip Trough Molding PB3 Intense Blue Pearl Coat RAAC All Radio Equipped Vehicles RABP AM/FM Radio RCDP 4 Speakers SBAP Power Rack and Pinion Steering SCEP Alcantara Wrap Steering Wheel TAAC All Tires TPFA P205/75R15 BSW All Season Tires WJDP 15X7.0 Styled Steel Wheels WLYC All Steel Wheels YCA Outside Lease 93016 YGAA Without Billable Fuel Z01P Rear Spring Group I Z63P Left Front Spring Group XII Z82P Right Front Spring Group XI 4FVP Assembly Plant Tracking 4HA Special Scheduling Condition I 4HC Special Scheduling Condition III 5KMA AMES Department Stores 8ED DESCRIPTION NOT AVAILABLE
Gearing down for the Diesel MJ. IL > PA > VA > IL
dasbulliwagen replied to Automan2164's topic in The Pub
:popcorn: :popcorn: -
I sat through that whole thing thinking I would see a Jeep, but there was nothing but the emblem to represent Jeep. That was 4 minutes of my life I will never get back.
