3
Will this 2.5 replace mine?
dasbulliwagen replied to pitbull4x4's topic in MJ Tech: Modification and Repairs
I don't know that ive ever seen it confirmed that port sizes changed on the change to port injection. Get the new motor, pull your intake off and compare the two. If they are the same, you can just swap your intake and exhaust and motor mounts over to the new block, and hope all the accessories bolt up like original. Let us know what you figure out. I'm curious to know as well if they are the same or not. -
Ford did re design the Ranger and Mazda B-series, but they arent going to sell them in the US, obviously. I agree, its kinda sad to think that the compact pickup market in the US is essentially dead.
Front Pipe/ Cat flange bolts
dasbulliwagen replied to UNL1MTD's topic in MJ Tech: Modification and Repairs
I would think that they are 5/16 or 3/8 bolts, but couldnt tell you the length. They really are nothing special, but if I were you, I would buy twice as many nuts as you need and double nut the bolts to act as a lock nut. -
There are a few on here doing that. Just go through the Projects section, and youll find some.
Need tire recommendations
dasbulliwagen replied to Rymanrph's topic in MJ Tech: Modification and Repairs
The Yokohama Geolander A/T is a very mild A/T and very highly rated for the price. I have a set on my Hyundai Tucson, and plan on getting a set for the MJ if I can ever get my BFG's to wear out. I think the BFG's will dry rot before they ever wear out, but the price on a new set of them is a bit out of my budget. Just my 2 cents! -
Recommended Upgrades???
dasbulliwagen replied to jamonroe75's topic in MJ Tech: Modification and Repairs
I agree about brake upgrades. If youre not sure which ones we're talking about Ill list them below. WJ or 96 XJ brake booster and master cylinder WJ front disk brake conversion with WJ knuckles removal of rear weight sensing valve with addition of XJ or ZJ or adjustable aftermarket proportioning valve Another good upgrade for the 2.5 is removal of engine driven fan with addition of temp controlled electric fan... frees up a few horspower. I'm not sure if you have any emmisions inspections where youre at, but gutting and sleeving the cat converter (or outright removal of it) will help a little too. Some will say the 2.5 needs the backpressure it provides to run properly, but this has not been my experience. I also added a Flowmaster 50 series Muffler for a little bit of growl without being too loud. This gives the little 2.5 a bit more pep. Like was said, better shocks will be good, a ZJ v8, or XJ country sway bar will help out. A ZJ V8 tie rod assy will help in the strength dept. WJ upper and lower front control arms will beef up front end strength too as well as add more clearance for bigger tires. Your best upgrade would be to get 4:10 gearing though. If you keep the 4 speed, add 4:10 gears, and 31 or 32 inch tires, your speedo will be pretty close to correct ( this assuming your original was 3:55 geared). Another great upgrade that would be good for your purposes would be a rear end upgrade to a dana 44, ford 8.8, or chrysler 8 1/4... get one with limited slip, or add a lunchbox locker, and youll be all set. I know the easiest would be to add a locker to your 35, but nobody really reccomends speding ANY money on a dana 35. -
I saw the title and thought you hurt yourself again. :fool:
Factory certified Chrysler Dodge Jeep tech, level 3 . And factory certified Mazda tech, senior level.
guess what I found... (warning: thunderchief photos inside)
dasbulliwagen replied to Pete M's topic in The Pub
Id like to see somebody do the header panel vent mod. Very nice! Good score Pete! -
The 4 ways pull a heavier electrical load, that may make the old T/S flasher work for now, but I would still take it to the parts store to get a new one. The 4 way that you plugged into the T/S is a heavy duty flasher. This is the same flasher that you would replace the regular flasher with if you had a towing setup and needed it to make the lights flash at normal rate. Get another heavy duty one and youll never have another problem with them.
87 comanche powersteering setup
dasbulliwagen replied to njcomanche1227's topic in MJ Tech: Modification and Repairs
Looking at my 87 4 cylinder, the answer is yes, but the air intake hose might make it difficult to get to the cap. I think pysically it will bolt up, but I'm not sure if the pulley would be correctly in line. Would be great if someone could try it if they have enough of both engines on hand.... maybe jimoshel can look at one for us??? :wavey: -
I guess I was wrong about the resevior too. At least when I was looking for one, I couldnt find any. I saw today that Crown and Quadratech have one listed now. I can get you a part number for it too if you need it. -
I had my parts dept look it up at my dealer, the part number is 53003805, cost is $36.25, and it is available to order through dealership Vintage Parts. This is the same pulley I bought for my P/S conversion. -
That looks like a V-belt pulley. They were only used in 86 and a few 87 models. I assume you have a serpentine style pulley. If thats the case, and the picture is correct, it won't work for you. -
swap the 4 way flasher with the turn signal flasher. If they start working and the 4 ways don't work, then get a new flasher. Ive seen one go bad on my boss's 88 MJ the same way. Let us know what you find.
If you go a little farther south to NC area, Ive seen them in the 3-4000 range for clean examples. The older ones usually go for 1500 or less. Go to this website that searches craigslist in multiple areas, and search areas in the south you woulldnt mind driving to, and find your XJ! www.searchtempest.com
Power steering help
dasbulliwagen replied to Jeepcomanche87's topic in MJ Tech: Modification and Repairs
viewtopic.php?f=2&t=33226 You may have seen it already, but the link above is for a thread with the same question on a 4 cyl MJ. -
The pulley spacing is application specific. I would not try it myself unless I had both of them in my hand to measure and compare. Call the dealership tommorow, and see if they can look one up, mention that you read where somebody got one from mopar restoration parts... that might help them to be able to look it up. -
91 Mj diesel swap
dasbulliwagen replied to 91dieseljeep's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Love the project, but that track bar looks pretty scary. I would worry about it bending if you ever go off road with it. And it doesnt look like you could use a drop pitman, it might cause the track bar and drag link to go out of parallel and cause bumpsteer. I think if it were mine, I might go with a really beefy drop bracket for the track bar so it wasnt as bent, and THEN go with a drop pitman to line up the drag link to the track bar. Just my 2 cents. Keep up the good work.- 34 replies
I just talked to my mom in Battle Creek, Michigan... she said they had about 8 inches on the ground. I hope theres more before I drive up there for christmas. It just wouldnt be right to have Christmas without some snow!
I converted mine a while back, but did not have a donor for the pump and resevior. The pump, pressure lines, and return hoses are available, but the pulley and the resevior are not. I found my pulley through the dealership in Mopar restoration parts... I'm not sure if they are still available or not, but NOBODY has a resevior, so if you can find a pump, pulley and resevior used for a 2.5 youll be ahead. I ended up using a resevior from a Dodge Journey as we were doing a recall on them, and one of them got a new recall resevior that didnt need it, so I put it on my truck... the hose sizes are the same as original and making a mounting bracket was easy enough. If youre getting a junkyard steering box, this would be a good time to go with one of the many upgrade units that we can use, I think they come from grand cherokees or dakotas, so do a little research on that and youll end up better than stock. There is an aluminum spacer behind the steering box mount that often breaks when you take it apart, so try to get one of those too if youre getting used parts. This is the best upgrade Ive done to my truck. Good luck! -
Throttle Body to carberator swap.
I doesnt have a normal style IAC, it has an idle solenoid that mounts next to the throttle body, and it has a plunger that pushes on the throttle linkage to idle it up or down as needed for cold start, AC operation, or in response to the power steering pressure switch. I don't have a pic, otherwise Id put one up for you. -
To expand on what Pete said, youll need a trans from an XJ or MJ with a 2.5 in it. Ones from a 4.0 will not bolt up without a rare and difficult to find 2.5 Dakota bellhousing or an expensive adapter kit. 2.5 XJ/MJ's with a 2.5 and a 5 speed usually came with 4:10 geared axles and would be perfect for a 4wd swap.
U-joint and C/V joint?
dasbulliwagen replied to Blue88Comanche's topic in MJ Tech: Modification and Repairs
The CV shafts from a WJ will not work, but ones from a ZJ will, though you may need to knock off the ABS tone ring if the CV shaft has one. In my experience at the dealership, Ive never seen a complete failure of a CV joint in a ZJ or WJ dana 30, but I often see boot problems which usually lead to shaft replacement, so that would be an area to keep an eye on. -
You need to look at fuel pressure and look for vacuum leaks, and if it sputters like mine did, it needs an oxygen sensor, you may also look to see if the converter is plugged, if you have good fuel, or if theres water in the fuel, change the crank sensor just because.... just changing to a carb is not going to solve all your problems, and in some places it is illegal. I'm not trying to sound harsh, but changing to a carb is not the answer. Start going through things one peice at a time, and eliminating items that might cause this. Be smart about it, and don't be afraid to ask for help here. Good luck.
