jons87mj
Contact Methods
  • AIM
    jonsjeepxj@aol.com
    evansville indiana
  • Interests
    working on jeeps
jons87mj's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. The fan pulls its power from the selanod under the hood. It has a fusible link and travels down and across the grill and back up to the relay. My truck was wrecked on the driver side front. It didn't look bad but it was just anof to cut the wire.
  2. ok so i replaced the wire to the alt to stud with 4gauge welding wire. and from there to battery with the same wire. i know have 14 volt at the battery when I'm off ideal. I'm going to do the grounds this weekend and see if it helps. thanks for the reply :)
  3. yes at the battery with it charing is 13.23 volts and i changed the alternator with a 200amp one (my buddy works at shop that rebuilds them)
  4. My 88 mj will only charge when you barely get it off ideal. When it does charge it only around 13 volts. I never had a dead battery from this but I feel something's not right. So what I'm asking is. Is this right are do I have a wiring problem? Any help would be great:D Thanks:)
  5. Hello:). I picked up a 96 jeep cherokee and the guy pulled out the factory steering colum and put in an older one. He got some of the wiring right but then some of it is not. Does anybody have a wiring diagram and know what wire does what on the 96 wiring? Thanks Jon
  6. With the sensor that low the coolant will cool down befor it reaches the senser. If you move it up to the thermostat housing then it will read the hotter coolant and will turn on sooner
  7. jons87mj
    Cargo Light
    Bump :)
  8. jons87mj
    Cargo Light
    Hi. I'm looking for a cargo light to put in my truck. I have the switch just need the the rest Thanks :)
  9. You will also need the speedo cable and the speed sensor that goes on the cable
  10. When I toke the swb skid off I broke all the bolts so I would assume that it has never been off befor. And it did not have the plastic skid in between the two
  11. Thanks for the replays :) ill just try and find a factory one. Seems like to much work to make the one I have work. Thanks again :)
  12. Really would appreciate any help with this:)
  13. Hello. I picked up a swb gas tank skid plate and was going to copy it but make the new one long so it would fit my lwb truck. But it looks like the mounting is different in the back. Does any body have pics of a lwb skid plat and how it mounts on a truck. Are if some one is willing to sell there's ;) Thank you
  14. I tested the fuel pressure and at idle its 30psi and when unplugged it goes to 39 and i did adjust the tps thanks Jon
