MiNi Beast
Everything posted by MiNi Beast
  1. insure good grounds as well. led resistors shouldn't be needed if swap out turn signal flasher with a $15 led flasher from your local auto parts store.
  2. need a led flasher either in fuse block or under knee kick panel below steering wheel.
  3. my first shirt i still have but it has since been some worn that it is literally falling apart. my hoodies are older and used but that makes for perfect jeep wear. never know when youll be on your back fixing something underneath.
  4. ill have my hat on and wearing my hoodie.
  5. here's a couple winter shots from my adventures. make me feel good.
  6. you should clean that up while you there. just sayin.
  7. heep is what i meant.
  8. well i know you can do it. however, i your efforts and your limitations. you are aware of your cabililites and know when to have it worked on by more knowledgeable people that have the time to dedicate to fixing the problem. please keep us updated as to the results. appreciate your being apart of the club. we all don't fix our own but its nice when we can as to save a few bucks. looking forward to a pic of you pushing snow in your heep.
  9. so just got my 231d tase that will be going behind the ax15. the rear output is different then our jeeps 231 output spline. however a simple swap of output shafts and id be good. however in my case, I'm having rear driveshaft rebuilt anyways as the length difference between an auto vs manual transmission will need to be address so at that point just running a new slip yoke that matches the 231D tcase and all will be good. or i could go the option of running a sye and double carden driveshaft but that be the more pricey option that i feel is not needed at this point. perhaps when i get 2k stimulus check .
  10. which one did you order? and what one were to to order?
  11. nice job on fireplace Pete looks great. and very nice project you did there Jesse. i enjoyed wood shop as well. sand it smooth.
  12. can't tell need to see it together and mounted and in the sun.
  13. they cruise on land ..
  14. nice. never too much sealer eh? thanks for pics. i need to do my pans very soon.
  15. so true. take good enough photo it adds thousands to the value.
  16. Thanks. I appreciate the comments. had fun with it this year. been a few years now that i have been doing this.
