MiNi Beast
Everything posted by MiNi Beast
  1. Yeah and them boys waiting till last few hrs to bid. I's gots gold fever!
  2. Cmon i want my precious 😩
  3. Good times at the races last night. Tonight be enjoying fireworks after being in pool all day. enjoy the day ya'll.
  4. Well sounds like adjustments to your new arms would help correct axle placement for sure. The sag may be a matter of a new replacement coil spring isolator. Typically isolator gives about 3/4" lift, however could be a sagging spring. Are the springs newer? Perhaps settling finally, more so could add a coil spacer to accommodate the sag and increase lift on drivers side.
  5. Bronze for 150 now. Wow. Must be the day to have.
  6. Press in lines have a plastic clip to secure it with a rubber oring to seal it. Typically replace orings when take apart for good measure. May need to disconnect battery terminals and touch them together and wait 15 seconds or so and reconnect battery and then start up and let it run a bit and relearn things. All the mean while by all means double check everything you messed with and ensure all is good.
  7. Get ax15 for for your year, pre 94, with internal slave. 95+ to utilize external slave bellhousing setup. Ensure input shaft tip will fit in crank bearing or bushing in 4.0. You will also need a crossmember for ax15 as well. Enjoy.
  8. Well, .. I have a factory box tapped, so furthermore my understanding is, I will need a v8 power steering pump or a high flow performance pump of some sorts. I currently have a psc high flow pump but Id be looking to replace that with a bigger resoviour setup. Also thinking 🤔 best to run a 1.5"x8" ram setup on my d44 setup. Need some lines made up as well, and have looked into rebuild able lines so can repair on trail if needed. Havent got to that point yet as maybe 😕 replacing 4.0 with a new rebuilt unit to ensure reliability and complete drivetrain upgrades for the next 5 years. Been busy though out in the woods lately. All in good time.
  9. We must be top rank eh..
  10. I know I'm due to rocket to the moon but why is there one by my name??
  11. Yeah have to relearn the sounds again.
  12. Very nice. Id still keep the bronze I reckon 😉
  13. MiNi Beast
    Beer
    Beer. Playing in the woods on master cabin build. Hot and sticky and a beer would be so refreshing.
  14. Your totally doing legit build journey. Nice.
  15. Awesomeness! Glad your here sharing with us your dream build. Look forward to many pictures and updates as you progress. Got questions please ask as many around here have been around these jeeps for a good while and may make it easier for you. Good knowledge base here be sure to tap into it and even contribute.
  16. Need more details about your plans. To be most cost and time effectiveness, what could you tell me about your truck drivetrains current condition? What direction are you looking to go with your MJ in regards to how you would like to utilize it... Daily driver? Weekend warrior? Rock crawler? Work horse?
  17. Jb weld for the win!!
  18. Your pushing to hard! 🤣
  19. Nice car. Both my brothers had one and tinkered with. Facebook price. 75k at auction with paperwork and cleaned 👌
