Pete M
Administrators
    114
Everything posted by Pete M
  1. tracbar will swap directly, but if you go up 3" then it'll be too short and the axle will be pulled to one side. 2wd MJs sit about one inch lower than 4wd MJs, so take that into consideration when calculating lift. :thumbsup:
  2. what happened to it?
  3. ignition switch bad?
  4. Pete M
    cat fight
    it's not what you think. :D http://www.youtube.com/watch_popup?v=9YnnKO-2Yko&vq=medium http://www.youtube.com/watch?v=9YnnKO-2Yko
  5. my 90 does it all the time. poor connection at the battery. clean it up and she fires right up. :) do the lights turn on?
  6. Pete M
    Bye bye
    ownership was never a requirement for membership. :thumbsup:
  7. hopefully the signup issues will be solved soon. :thumbsup:
  8. actually it's the peugeot and AX-15 that are the same length. The AW4 trans is a bit longer. :thumbsup:
  9. Depends, who is your current host? As long as they support MySQL 5+ and PHP 5.3+ running under Linux it should be fine. does it easily support a smart phone program? I can deal with the glitches, but we could really use a tapatalk or forum runner or the like.
  10. I do believe you'll need a 4wd cable (I think the 2wd one is too short) make sure you get the right gear/shaft for inside. there are some difference over the years. and the gears change depending on the tire size. but the gears pull right off the shafts so you can mix/match to get it right.
  11. I'm guessing I'd have to give up my current host?
  12. amen :cheers:
  13. tried car-part.com yet?
  14. Pete M
    Dually?
    that too. I once got stuck on slimy gravel on the side of the road because the tow rig I was borrowing didn't have 4wd.
  15. I would be willing to help give the entire site an overhaul. :D I have some experience developing forum sites... http://www.minecraftforum.net/ http://www.mmo-champion.com/ http://www.arenajunkies.com/ http://www.diablofans.com/ +70 more in the Curse Network Though I would want to change up all the software for a newer IP.Board installation. is that software free?
  16. which is unfortunately not easy to integrate into the forum... :fs1:
  17. :drool: :drool: :drool:
  18. 3.5k?!?! :nuts: that's what you get for living in that strange foreign country. :rotf:
  19. :wavey: we missed ya Wade! so when you getting that next coman-che? :brows: you should be able to pick up a little beater to play with for a few hundred buckaroos.
  20. Pete M
    Dually?
    don't forget brakes, brakes and more brakes.
  21. my mj needs a supercharger. :D no action shots?
  22. caster. it means that the truck will be more likely to wander down the road rather than have a firmer return-to-center feel. our trucks have around 5* of caster. I'm sure there's a way around it, I'm just not too up on the scout axles. the caster thing stuck in my head years ago because I couldn't figure out why they would do such a weird thing. :dunno: I wonder if those have big ujoints or small ones. :hmm: my fav junkyard swap is the grand waggy front and an Isuzu rodeo rear (mostly because the Isuzu comes with great gear ratios and so then I'd only need to regear one axle)
  23. central axle disconnect. :thumbsup:
  24. been there, done that (like 20 years ago)... it was awesome! :yes: one of the last steam monsters left that's still in semi-regular use.
