Well eagle the new bearings arre stamped STD on back sides of bearings.As for the orientation of them #1 at #1 cylinder then 2 through 6.When I'm looking at the engine from underneath passengers side all numbers face me correct me if I'm wrong but thats wright.Correct also if the connecting rod bearings are torqued an the main caps are loose it will spin.Also for torqueing them down start from center #4 cap then 3,5,2,6,1,7, an all torqued to 80 ft lbs. I'm wondering if maybe i should oil up the cylinder walls an try it.
