Pete M
Administrators
    114
Everything posted by Pete M
  1. YES! :clapping: I vote RC MJ too! :yes: else what would we do for the calander? :dunno:
  2. As I understandd it, they are using the 4.0 throttle body and putting the 2.5s injector assembly on it. The 4.0 has a larger diameter hole for more airflow. :thumbsup:
  3. fwiw, 33s are less of a headache and only lose 1" of ground clearance vs 35s. :thumbsup: I don't know of any junkyard options to gain an inch on 4.0/stick rear driveshaft. :dunno:
  4. sweet! :bowdown: though I half-expected to see that you traded one MJ... for 2 MJs. :yes:
  5. it's always a good strength upgrade :thumbsup: , but isn't really needed in an MJ until 6+, and even then some guys don't have them. we have a much longer wheelbase than wranglers and cherokees and so we don't suffer the sharp driveline angles that they do. but you will want a longer driveshaft at 4+. unless you upgrade the rear axle (which I highly recommend if you want big tires), which the new axle will have a longer snout on it and so balance out the height. what are you doing for gears and axles? oh, and welcome to the club! :waving:
  6. you'll love it! :thumbsup: I've got one from every year and the 87 is my favorite. :yes: (has both MJ and the fullsize stuff in it)
  7. if you have a 4.0, the upper bolts will be the reverse torx head bolts so be prepared. I'm thinking they are an E-12 size? Whatever they are, do yourself a favor and DON'T reuse them. at the very least get normal hex heads, but I recommend getting studs for the upper bolts. that way they work as a guide for re-installation. :thumbsup:
  8. gotta find the little picture of a tree (the photo button). click it, and then paste the address into the box that pops up. :thumbsup: guess we should probably update the "how to" post on uploading photos.
  9. :eek:
  10. :redX: though with this software, I can't tell why. :dunno:
  11. I originally used a small juice bottle but the truck filled it up and started spitting out oil after only a few hours on the freeway. so I supersized it. :D
  12. we'll have coozies in a couple days so at least you'll have cold beer while trying to navagate the craziness. :D also, if you thought your end of this menu-insanity was confusing, try being a mod or admin. layers upon layers of new gibberish. thank goodness for Alexia! I can only imagine trying to do a switch like this by myself. :help: also-also, some smilies seem to have disappeared. :dunno: Item 151 on today's glitch list. We've got all the problems of a major theme park and a major zoo...
  13. Pete M
    Strange Hate.
    ask him to try a steep incline. :yes:
  14. I've ordered 300. there should be plenty. :thumbsup:
  15. I still need to fix a couple of smiles. the new software substituted its own for a few of the more common ones.
  16. Mech fans pull a great deal of air. sure this one will substitute? might work better as an aux fan. and don't assume it'll fit. our radiators are pretty dang short from top to bottom. :( .
  17. should be in by the end of this week. there was apparently a mixup (isn't there always? :fs2: ) but everything is straight now. apparently. :dunno:
  18. I do beleive you should run the Chevy flywheel :thumbsup:
  19. whoops. I think that was me. :doh: was playing around with things. I'll see if I can undo that.
  20. by the way, the "quick reply" box is nice :yes: .
  21. and how do I get the IP board to never change topics to "read" unleass I've read them?
  22. we're getting there. it's going to be a process to iron out issues and get it to act more like the old forums. :thumbsup: I added in a question for new sign ups. I'm assuming that should cut down on spammers, though I'm not certain what was in place before. I just know it said there were 0 questions.
  23. good one! used to have one of those. :D
  24. I've been hesitant to do that since if rust starts under the layer of liner (rust can also start under the truck or in the frame), it's nearly impossible to notice or treat. :dunno:
  25. they look brand new! :yes:
