114
Everything posted by Pete M
dragging my finger across that little pad seems to affect said finger in a negative way. after a short while the tip of my index goes tingly and then numb. same with smart phones. apparently I didn't get the best genes in the world... :dunno:
Replacement For A 2.5 Tb?
Pete M replied to Zenobian_84's topic in MJ Tech: Modification and Repairs
if you own a 2.5, always always always grab 2.5 injectors if you see them at the 'yard :thumbsup: -
I don't see a button on the reciever. . . :(
How High Can You Go Until Sye
Pete M replied to swirlytwirlys's topic in MJ Tech: Modification and Repairs
the more you spend on shocks, the better they are. :thumbsup: -
:rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf:
smiles, friends, knowledge, confidence, noteriety, memories, more comanches... and an uneasy relationship with my city... :rotf:
love it! :thumbsup:
find the photo button (right beow the smilie face), click it and a new window pops up. just paste the image address in ther and you're good to go. :thumbsup:
I'm changing my vote to the trailer since we can have that up in no time at all. :thumbsup:
take that causality!!
don't you mean "you just lost fiiiiiiiive dollars.." :rotf:
under 5 bucks shipped. might be the same mouse. :D and yes, the batteries check out as good.
bought a cheap-as-hell wirelless mouse off ebay and shipped from china. the driver seems to have loaded properly, but all the mouse does is blick once or twice when I turn it on. then nothing. No paperwork to check, no part number to look up. got what I paid for I guess. :yes: ideas? I've sent an email to the seller, but lord only knows how good their english will be. :dunno:
YES! :clapping: I vote RC MJ too! :yes: else what would we do for the calander? :dunno:
As I understandd it, they are using the 4.0 throttle body and putting the 2.5s injector assembly on it. The 4.0 has a larger diameter hole for more airflow. :thumbsup: -
fwiw, 33s are less of a headache and only lose 1" of ground clearance vs 35s. :thumbsup: I don't know of any junkyard options to gain an inch on 4.0/stick rear driveshaft. :dunno: -
sweet! :bowdown: though I half-expected to see that you traded one MJ... for 2 MJs. :yes:
it's always a good strength upgrade :thumbsup: , but isn't really needed in an MJ until 6+, and even then some guys don't have them. we have a much longer wheelbase than wranglers and cherokees and so we don't suffer the sharp driveline angles that they do. but you will want a longer driveshaft at 4+. unless you upgrade the rear axle (which I highly recommend if you want big tires), which the new axle will have a longer snout on it and so balance out the height. what are you doing for gears and axles? oh, and welcome to the club! :waving: -
you'll love it! :thumbsup: I've got one from every year and the 87 is my favorite. :yes: (has both MJ and the fullsize stuff in it)
Remove Transmission Without Engine
Pete M replied to Oddmodman's topic in MJ Tech: Modification and Repairs
if you have a 4.0, the upper bolts will be the reverse torx head bolts so be prepared. I'm thinking they are an E-12 size? Whatever they are, do yourself a favor and DON'T reuse them. at the very least get normal hex heads, but I recommend getting studs for the upper bolts. that way they work as a guide for re-installation. :thumbsup: -
gotta find the little picture of a tree (the photo button). click it, and then paste the address into the box that pops up. :thumbsup: guess we should probably update the "how to" post on uploading photos.
:eek:
:redX: though with this software, I can't tell why. :dunno:
Catch Cans, Anyone Use Them?
Pete M replied to Blue88Comanche's topic in MJ Tech: Modification and Repairs
I originally used a small juice bottle but the truck filled it up and started spitting out oil after only a few hours on the freeway. so I supersized it. :D -
we'll have coozies in a couple days so at least you'll have cold beer while trying to navagate the craziness. :D also, if you thought your end of this menu-insanity was confusing, try being a mod or admin. layers upon layers of new gibberish. thank goodness for Alexia! I can only imagine trying to do a switch like this by myself. :help: also-also, some smilies seem to have disappeared. :dunno: Item 151 on today's glitch list. We've got all the problems of a major theme park and a major zoo...
