Pete M
Administrators
    114
Everything posted by Pete M
  1. and a factory bedliner hey, that site lists vins! this truck is now added.
  2. Pete M
    1JTML63SXJT001244
  3. Pete M
    1JTMW6415JT031412
  4. while you're in there, check the frame for any cracking between the track bar bracket and the steering box.
  5. some might actually sell them for cores to rebuilders. that and the "environmental fee" are just ways for them to advertise a lower price.
  6. if you bring your old trans to them, they give you your 30 bucks back. (ended up with some weird alliteration in that sentence)
  7. that's Rob's (automan2164) site from way back when. glad to see it's still hanging around.
  8. now THAT is something I'd want to take to the car shows. gorgeous!
  9. at a self serve? 75-150.
  10. be sure to undo all the interior and then remove the stickshift tower before dropping the trans/crossmember. you'll only forget to do that once.
  11. it's possible it's been swapped. can't know for sure without crawling underneath.
  12. definitely in need of some love. but score none the less
  13. it's an 88 which got the peugeot from the factory
  14. Pete M
    How many
    1: holy crap that's a lot of typing 2: no doubt. although some people also fill it in with info that's not strictly a town/state 3: what I mean is, just because they put their city in their info (if you see the post, there's the city) doesn't necessarily mean that they want their name to be found when someone searches the map. plus there would be a TON of members added to the map that no longer participate in CC. doesn't our software already have a section for who's been online lately? or is that just for who is online right now?
  15. Pete M
    How many
    those 2 are the most likely to have the answer. I've got no idea of how much work it would entail. 2 thoughts: very few people actually fill that info in. you may be getting into the territory of "needing consent".
  16. Pete M
    How many
    look at the map (edit: which I say and then see there's only coffman listed there. there are a couple more. you might need to run a search though)
  17. Pete M
    How many
    pinned near the top of the Pub is a thread containing the members map
  18. but it had problems with bending into a smile. both the 20 and the 44 are in the same basic class. better than a 35, less so than a 60.
  19. sounds like a good time to make a doctors appt.
  20. your body is moving way too much relative to the axle so that helps narrow down where to look. also, sawing the wheel back and forth rapidly from like 10-2 oclock works better at finding movement than the slow back and forth.
  21. did they strip it bare to do the repaint or did they mask things?
  22. I can see your track bar bracket moving
  23. car-part.com can help you with what ratios were available each year. search MJ rear axles if you want to weed out the XJ stuff
