SayBye
1 Follower
    Chattanooga TN
976 profile views
SayBye's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. Is this 12k worth of Comanche? Really thinking about buying this week, and obviously ponying up on the cash for this one.
  2. Then the fuel pump hot and/or ground wire has an air gap caused by whatever you removed. Follow the wires from the fuel pump and see where the break is. BTW, what model/engine/etc. is/was the truck? It's an 89 4.0 auto 4x4.
  3. Unscrew and remove the left tail lamp from the fender. The ground connection is a sheet metal screw fastening several wires, including the fuel pump ground wire, to ground behind the lamp. No tail lights or bed sides were on the truck when I got it but it ran fine til I pulled the bed off.
  4. Unscrew and remove the left tail lamp from the fender. The ground connection is a sheet metal screw fastening several wires, including the fuel pump ground wire, to ground behind the lamp. The bed skins were cut off by a PO and they were using it as a flat bed on the farm. So no tails light, all that was there was the bed floor.
  5. I pulled my mj into the garage yesterday to pull the bed off and now the fuel pump won't come on. I read where there's a ground behind the tail light, I don't see any evidence I ever had one of this truck. I read where the relay is located, swapped them out with others from the rack, still nothing. So number one is how to I check my voltage at my relay center? I was getting like 4.2v there yesterday but I'm not sure I was checking it right, however I was getting that same reading at the fuel pump disconnect. I'm trying to find the resistor under the hood by the headlight relay? I read its white, does anyone have a picture of it because I'm just not seeing it. I ran two wire from the batt. Straight to the fuel pump and it fires right up and the truck runs normal. Where does the relay center get its voltage from? Thanks guys!
  6. They should all be the same, I'm pretty sure.... ?
  7. hahaha trust me the light and the front bumper will be the first things to go once its in my hands.
  8. That's correct, it would be basically just swapping sheet metal from one MJ to the other. As far as the 91 frame goes, it should be good (it was when I owned it.)
  9. I would agree and that's def not out of the question. The 86 is an auto, I'm assuming its an AW4 or were they making AW4's that far back?
  10. and here is the 86 I bought to use as the donor truck...
  11. the day I sold the 91 to them 2 years ago...
  12. here's the 91 now...
  13. I am talking about taking all the panels off the 91 except obviously for the cab, and replacing them with everything off the 86. Bed, fenders, doors, etc. I haven't decided if I'm gonna go with a 97-up front clip yet, I kinda dig the old style headlights and grill myself. The 91 is beat all to hell now. Itll take some time but I think its worth saving. One thing I was wondering is do the unibodys on these trucks twist/flex as bad as the XJ's do? That's the only thing that worries me is taking all the old stuff off and none of the 86 stuff lining up due to the 91 being taken offroad so much. Ill upload some pics of both the trucks...
  14. I bought an 86 lwb over the weekend with a solid body, striaght for the most part with a few dings. Two years ago I sold a 91 lwb metric ton package truck and that owner still owns it. It's been beat to gel since then. I would eventually like to have a clean lwb truck. Do you guys thinks it's worth the time of swapping everything off the 86 to the 91? The 91 has 154k on it. I'd post some pics but I'll have to host them and can't do it from my phone...
  15. I would rather use tube but Ive got a harbor freight bender so the dyes are for pipe, plus pipe is easier to come by for me than tube. Ive made several sliders and bumpers out of 1.25 pipe and they held up fine, just never used the 1" stuff before.
