Pete M
Administrators
    114
Everything posted by Pete M
  1. Pete M
    Tool Talk
    so this is a combination of growing up in the salt belt and my general tiredness lately, but I most definitely assumed the worst without actually verifying anything. the nut under the floor is both accessible and in perfect shape. the stud is simply unscrewing from it. but I might still get myself a new tool for christmas.
  2. Pete M
    Tool Talk
    not sure. I guess I assumed it was inside the frame, but I should probably confirm that first.
  3. dang! trigger on the pneumatic greaser get stuck?
  4. inventing stuff takes time. you'll get there.
  5. Pete M
    Tool Talk
    looks like I'm about to invest in a pass-thru ratchet set. I can't figure out another way to undo the lowest bolt in the bench seat (the stud just spins and I'm not ready to sacrifice the bracket or damage the carpet) and figure it's worth a shot to slice a groove in the top of the stud, then use the a pass thru to move the nut while a flathead holds the stud still.
  6. I've got a TJ trans in my 88 and appreciate the bit of extra t-case ground clearance that the extra clocking gives.
  7. if you want power, I don't think you'll be happy with the little diesels. don't get me wrong, it can be made to work. but... meanwhile you can get 400+ out of that LS pretty easy.
  8. you're trying to get it to run right before swapping out a bad head gasket?
  9. Pete M
    240z
    um, duh! I'd wager that most every guy/gal interested in cool old Jeeps is also likely interested in cool old cars.
  10. an AX-15 is an AX-15. the length is constant. if the trans has a thick aluminum plate between the front and rear halves of the case, it's an AX-15,. But if the trans has a thick steel plate between the front and rear halve of the case, it's an AX-5 and that won't work for you at all. they look similar, but the middle plate gives it away (also the bolt pattern for the bellhousing is very different but the bell isn't always there). the 231 found in the old Jeeps comes in unsealed rear (89 through maybe 96?) and sealed rears (anything after that). can't say I'm 100 percent that they are the same overall length or not. also, your AX-15 is rebuildable.
  11. I found 93s, 94s, and 95s in the yards over the past month and all were crumbled up. quite possible that the change to the newer plastic was mid-year. I'll keep checking 95s. at this point I think I'm going to start buying up all I can find since XJs are becoming harder to find.
  12. good idea. maybe it'll come with the next upgrade. we're kinda overdue for that.
  13. Pete M
    1jths641xht151066
    guessing on year. completely forgot to snap a pic of the truck. lol. very bare bones truck. it's at Foss you pull in NC.
  14. I should also add that 97 up are slightly different but probably still usable in our trucks. Maybe? I believe the 96 are the same as ours, but I guess if haven't held an intact 95-down in my hand in quite some time
  15. After much checking out of cherokees, it appears that only 96 got the plastic upgrade that 97 plus got. So if you find them they will not disintegrate on you like the older stuff.
  16. Bar is gone gents. Sorry.
  17. Lol. Be sure to post in the classifieds.
  18. nice! did it go to a regular junkyard? maybe you can buy the whole thing?
  19. also, according to the site it's been there for a couple weeks. either the bar is long gone already, or you've got a few weeks before it's crushed.
  20. to most people in rust free areas, it's just an old small truck.
  21. for C02 I use a standard 20# steel tank filled up at a local welding supply shop. I use a non-adjustable 100psi regulator with no gauges. works great for filling tires and blowing a steam of air to clean things. if you want to use it for things like a brad gun, you'll want an adjustable reg with a gauge.
  22. too expensive for a middle man. by the time I add in the gas costs to pick that up and haul it north, I might make my money back.
  23. lemme know how the bed is.
