HOrnbrod
Moderators
    28
Everything posted by HOrnbrod
  1. If you read the link, the p/n for the nipple is there, 53007563.. https://www.moparpartsgiant.com/parts/dodge-connector-oil-filter~53007563.html
  2. Yes. Most all of them will interchange. The major differences were the pin-out locations on the connector. You might lose TC lockup IIRC. The 92 be good enough for troubleshooting..
  3. A 5-sec search for "nipple" yielded this: http://www.fourwheeler.com/how-to/5421/
  4. Look for a Dana xx (35, 44, etc.) U-Bolt Style Pinion Yoke Kit on Ebay, Amazon, etc. They range in price from ~$40 (Crown, Rustys, etc.) to ~$80 (DanaSpicer).
  5. What rear axle do you have? You really should add a signature to your profile...
  6. Gasp!! Is that rust I see??
  7. What year was the XJ you got the seats from? If 93 or below, the XJ seats will bolt directly to your bench brackets. Also I don't any seat back levers on you're 2DR XJ seats...
  8. There are some on Ebay. W/o the dealer DBR II test set, there 's really only one way to check the AW4 TCU out; replace it with another.
  9. You replace the axle pinion yoke with a new u-bolt kit like this:
  10. Si, if you plan on removing the topper at times. Mine's a permanent fixture and bolted solid using eye--bolts for tying things down inside.
  11. Not necessarily, but it could possibly be a bad TCU. You're not going to find this part at any auto parts store - junkyard item only. I have a few new and used - what's the p/n on your TCU tag? Assuming you have a 91 it should be 53008383.
  12. Consider junking the weak u-joint straps by replacing the yokes with the 1310 u-bolt style. Much stronger and easier replacement.
  13. Mine is not wired for it either and there's nothing in the 91-93 parts manual for an MJ cargo light either. And Adam's p/n on his instruction sheet doesn't come up in any of the manuals. Weird... Here it is in the 87-90 manual:
  14. Is that a pic of your 91 cargo light Schardien? I ask because the MJ cargo light (p/n 56000846) is listed in the 86-90 parts manual but not in the 91-93 manual. Did the HOs ever come with the cargo light or is this just an omission in the parts manual?
  15. Long beds rule.
  16. Commanche Run could run!
  17. Jeesh, what an idiot. Ford Commanche - that's a first.
  18. HOrnbrod
    Station Wagons
    To me the 55-57 Nomads were the best looking wagons ever..
  19. Probably if you used longer bolts. Can't really tell w/o a pic.
  20. Looks like it to me. It has what looks like a D44 and 4+1 MT springs.
  21. Good to know about the K80036 links. I'm using both the K80035 links and the Synergy brackets and the bar is aligned perfectly. But I'm sure your truck is taller than mine...
  22. Dirty, you might get by with just some longer end links. The MOOG K80035 links are about 3" longer than stock, fit perfectly, and are available on Amazon for just $5.78/ea with free shipping on orders of $25. Can't even buy new bushings for that. https://www.amazon.com/Moog-K80035-Stabilizer-Bar-Link/dp/B000C544K0
  23. Another way: Swaybar Relocation Brackets
  24. Yes, MJs and XJs. It was manufactured by Ramsey and was an option available from the dealership. PDF attached... Ramsey Hidden Winch XJ.pdf
  25. That unit sure looks foreign in a stock MJ dash.
