87manche1
Everything posted by 87manche1
  1. http://akroncanton.craigslist.org/bar/3732914867.html
  2. Looks to new crd liberty engine? Made in Europe
  3. Next guess then ill stop isuzu?
  4. I don't know diesels so ill stab at it. Mercedes diesel
  5. Check floors of course. Yea without paperwork I wouldn't either. Check for spliced and tape wires. oil leaks. Make sure 4x4 works.
  6. Per old post he has an 87 so renix. check cruisers his link .what happened ur lsst no start in 2012.
  7. Pics and how to please
  8. Its the trackbar if one stays the same ur axle is fubar and I doubt that. Take a pic
  9. http://autorepair.about.com/od/enginetroubleshootin1/ss/compress_test_2.htm
  10. Go to autozone rent a compression tester. Should come with instructions. Or google it
  11. No only if oil gets blown back into the piston Or valve seals. Or U could also have a stuck injector check for fuel pressure bleed down. If that passes do a engine compression test
  12. Probly blow by worn out rings
  13. Dash ground is wire on the lower driver side dash with the lower dash removed it is easier to see
  14. Yea there were lots on there couldn't see lengths.
  15. Right if u were near ohio I'd give away my short bed cap
  16. Supposivly 2 inches I haven't tried it tho
  17. Ah might be better for a 5 inch lift then
  18. Rear f350 links 2 inch longer http://item.mobileweb.ebay.com/viewitem?itemId=140339183486
  19. Also the rear valve cover hose is mia
  20. 87manche1
    '87 Mj
    Lol needed a laugh today thanks guys
  21. Manche sun visors are longer replace with xj ones and u can put back in same spot
  22. One by vacuum res. ( air bubble) is probly for a horn
  23. Love these shocks can't wait to get them on the comanche. I did soa so I have to relocate the mounts
