87manche1
Everything posted by 87manche1
  1. Airspeed I agree do a leak down test plus u could see bubbles in the antifreeze if ur head gasket is leaking
  2. Jim I hate u.... lol lucky man
  3. My buddy is going in one of his jeeps. I wish I could make it
  4. http://akroncanton.craigslist.org/cto/3944742049.html Wonder how he got the body lift on.
  5. Pressure test the cylinders with air. And do it that way but could get mixed readings threw blow by of the rings.
  6. Vent is probably clogged its a rubber tube usually run up the dipstick and has a white cap. Most auto transmissions have a filter kits probably aroung 35 then the cost of trans fluid
  7. Yep and I think there's no axles either he says "setup up for 4 link". Don't sound like 1500 to me
  8. The 89 is a cherokee shouldve been more clear
  9. Nope no comanches only one was in east Cleveland months ago
  10. akron ohio pulla part has a clean 89 with a super nice chrome grill. and 2 newer cherokees 97+ with nice header panels and doors. Just a heads up for u ne ohio guys. Sorry no pics didn't have my phone
  11. Vise grips or cut it off and replace
  12. First pic is vaccum line for the heater valve that isn't there anymore. Last pic vaccum for map sensor? 3 is probly the vent tube for the trans bolts to the bell housing
  13. Think they hate caravans more
  14. The drop brackets are causing the fixed length control arms to push the axle forward. With drop brackets and 4 1/2 arms u can run 6 inch springs. So answer arms are to long. And do u have a track bar for lift or oem?
  15. Got mine from crown offroad never had a problem
  16. http://www.quadratec.com/products/52207_0007.htm transfer set. They gotta have it
  17. http://www.quadratec.com/products/52218_0014.htm transfer
  18. Condesor, lines , canister. there's allot to it plus u have to wire the compressor and switches . Go to jy get comp lines and metering get a new evap and condensor. I don't trust those used.
  19. Could have a loose chain maybe skipping teeth? Look inside the drain and fill holes any metal shavings in the fluid?
  20. But I found out u have it on backwards heim is supposed to go to drop and bushing goes to axle. U check warranty?
  21. Sorry I'm mistaken. They upgraded the control arm
