87manche1
Everything posted by 87manche1
  1. Rc upgraded they're heim joints should be replaceable
  2. Ur on facebook awesome they did that
  3. 4 door or extended cab time? Glad ur alright considering
  4. Just the length when u swap to 4x4 is the issue
  5. Front lift above 3 inch ull need trackbar, control arms or control arm brackets or both, shocks, swaybar endlinks ect. To me I like around 4.5 costs can vary 450-700 depends who u go with
  6. I like skinny tire sizes like 32x10.5. ran 285/75/16s mt for awhile and hated them. Liked the firestone mt good tread wear longer life and threw some mud. Ejection out of the tread is to me essential if it gets packed in What's the point
  7. Only thing I've heard is weld on shock mounts to the axle. You would have to run smaller shocks
  8. I have a 96 xj console in mine from a auto remember to grab the brackets
  9. Like this?http://www.virtualjeepclub.com/showthread.php?72689-Can-I-switch-my-instrument-cluster
  10. Been swapped?http://www.roadkillcustoms.com/hot-rods-rat-rods/Transmission-Cross-Reference-Database.asp?Transmission=904 Says 904 was last used in 86 or u have a mismatched end of model yr truck
  11. Column shift? Should clip onto the shift collar somewhere
  12. Better to use s10 or ranger dakota leafs the xjs leaf have a different arch and might actually lower it
  13. I got an 94 explorer 4dr rear driveshaft for my soa 4x4 swap
  14. Won't work for a short bed so doubt long bed
  15. Much better without the steps
  16. Trapped air in the lines?
  17. U look into fan clutch?
  18. As long as the flywheel stays on the crank ur ok
  19. There's multiple holes its obviously going to be the ones with a spot of no rust where it bolts to
  20. Ull find something got mine for 700 so far up to 1100 with lift / repairs
  21. Guys been trying to sell it for a yr not worth what he wants
  22. http://toledo.craigslist.org/cto/3768689269.html not bad for a grand
  23. http://detroit.craigslist.org/okl/cto/3767018212.html
