Well, I replaced the pitman are with a drop arm and it helps but still hits the end link.
Funny you say that. The old style RE swaybar disconnects were straight. They use a metal spacer to space the link out from the mount. In the first pic you can see I replaced the spacer with a couple washers that were much thinner then the spacer. I was trying to make the tierod clear.
I went to my parts pile and found a pair of Full Traction swaybar disconnects off my buddies old TJ. They have bend in them which eliminates the spacer.
Houston, we have clearance!
Not sure you could slide a piece of paper between them but they clear. It does hit the end link mount at almost full clock but a little love with the grinder should fix that.
