87manche1
Everything posted by 87manche1
  1. Ok i tested a spare i had 104ohms empty 1 ohm full should ramp smoothly
  2. http://www.jeeptech.com/electrical/gauges/ I don't know how accurate this is.
  3. Yea with an ohm meter i don't know the ohm value at what level tho. Fuse is 5 amps says instrument lights
  4. Ie i hate fords. Think that gate would look better on a truck
  5. I like it rather use a ford tailgate tho.
  6. What? :hmm: All issues are cluster related and are not ecu issues so essentially as long as u reground those wires ull be fine check those wires i just sentGot those colors from my manual the wiper black is a ground rest is 12v+. Also check black ground from cluster goes straight to ground.
  7. For wipers black wire off wiper module Fuel gauge tan wire from cluster to fuel sender after it goes threw potentiometers to ground For dash lightd check org/black wire from headlight switch goes to fuse box out of fuse box to org/black to the cluster check for a short to ground nicks ect
  8. Well right now all the issues with cluster are none ecu issues.
  9. U have to pull lower plastic dash
  10. http://comancheclub.com/topic/36382-cruisers-renix-tips/ Was wrong read cruisers dash ground refresher right where he said
  11. If for a light ect sure something that goes thru ecu probly not.
  12. Haha I'm sorry had to laugh glad u got it man
  13. Internut lol lets all get together and love ur fellow man man
  14. Metric ton is rare. Pics?? And welcome
  15. Driverside kick panel there is a black bar attached to the body going to steering column. Below or above it where mounts to body is where the ground is look up cruisers tips ground refreshing. Ill take a pic in a bit
  16. Sorry reread ur first post.
  17. Bleeders actually bleeding? Ive had rubber hoses clogg and wouldnt relieve pressure never a no stop issue like this. Did u replace allot of line?
  18. Kinda thinking the mc needs bench bleed.
  19. My procedure 2 guys. 1 pumps brakes 3 times and holds while holding guy 2 opens bleeder and closes repeat til no air comes out work furthest first. 1 guy fill container half way with brake fluid open bleeder put hose on bleeder and other end submerged in container and pump away slowly I like the 2 man more accurate as 1 man job u can't see air..
  20. Tell us ur bleeding procedure i think somethings up.
  21. Tonight made a headache rack to add lights to the top mount fire extinguisher maybe a highlift/ offroad gear. gonna add netting later. List of stuff to do Finish paint Get control arm drop kit shocks Finish bucket seat swap and floors Swaybar disconnects Ect
  22. I got the name project tar because the guy mostve smoked 4 packs a day in it. I cleaned the interior and started work. Picked up a 96 4x4 cherokee converted the comanche to 4x4 swapped in the ho head intake and exhaust. Did the soa and lifted the front 6.5
  23. So about 3 months ive had project tar. It came off lake erie coast east of Cleveland 4.0 auto 2wd 185k miles got it for $700 Day i got it
