My 88 4.0 would'nt start just cranks. Pulled the plug to the fuel pump at the tank for a voltage check, turned the starter and it fired. Plugged it back in and ran fine. Coincidence? Had to do same thing to get it running the 2nd time.
Anyone
Has anyone removed these cap successfully without damage?You know the cap braces on top of the mj floor which make it hard to keep your feet flat! Mine are in decent shape and would like an idea or 2 to get started, so I can replace the floor TIA
https://lh3.googleusercontent.com/-XRnlnO5-lkI/U3QPH0_JKEI/AAAAAAAAABk/O1DR2pz1w34/w1153-h865-no/P1030887.JPG
hey maniac, did you drill out the spot welds to remove the frame cap? mine are in decent shape but to do a decent job on the floor i would like to remove them without damage.
hey Guys
Been following this and have elliminated the prop valve, it was pooched anyway!
, just wondering about the plug @ the routing block. Is there such a part for this or did you just cut the line and seal it?
