chappy88
Everything posted by chappy88
  1. Nice truck, where did the shifter knob come from? Love to have one myself!
  2. Hi Guys Small but annoying...parking brake light stays lit when key is off?? was going to remove bulb but its a good reminder to save the brakes
  3. Not yet,At the tank for the pump I'm guessing?
  4. My 88 4.0 would'nt start just cranks. Pulled the plug to the fuel pump at the tank for a voltage check, turned the starter and it fired. Plugged it back in and ran fine. Coincidence? Had to do same thing to get it running the 2nd time. Anyone
  5. sorry front axle :doh:
  6. Anyone know if 92xj (auto tranny,same engine) front end would work on my 88mj (manual) or know where I could find out for sure?
  7. My 88 mj has no tach and dummie lights, how much work would it be to install a cluster with tach and guages from an 91 xj, or is it possible at all?
  8. thanks guys..not a body man! nice to know something exsists
  9. Has anyone removed these cap successfully without damage?You know the cap braces on top of the mj floor which make it hard to keep your feet flat! Mine are in decent shape and would like an idea or 2 to get started, so I can replace the floor TIA https://lh3.googleusercontent.com/-XRnlnO5-lkI/U3QPH0_JKEI/AAAAAAAAABk/O1DR2pz1w34/w1153-h865-no/P1030887.JPG
  10. hey maniac, did you drill out the spot welds to remove the frame cap? mine are in decent shape but to do a decent job on the floor i would like to remove them without damage.
  11. hey Guys Been following this and have elliminated the prop valve, it was pooched anyway! , just wondering about the plug @ the routing block. Is there such a part for this or did you just cut the line and seal it?
  12. Well I bought this truck new and the frame is as it was new. Gotta get some pics.
  13. I don't have much luck getting pics on this site! I can try again.
  14. OK! I'm convinced, no drop.....still doesn't line up with frame holes, have a fab guy going to make adapter. thz guys
  15. Any idea on adding a skid plate? since you guys talked me out of dropping the cross member, I'm again looking for some good info :laughin:
  16. since my mj was 2wd, I'll have to get the shaft shortened, any problems with that?
  17. I have already put the 91 Cherokee 4x4 drive train in the 88MJ and added 4.5 rough Country kit without 2 many hassles. The kit came with the spacers to drop the cross member 1.5" ....and the installation manual backs it up. You guys are talking Wanglers and Newer model TJ's . Are you guys speaking from experience with XJ's and MJ's?
  18. That's exactly what we are doing as well...added a 4.5 rough country to our 2x4 mj with xj donor 4x4. The cross member doesn't line up , but a fab buddy of mine has an idea. we have to drop the cross member 1.5" anyway, so instead of using the provided nylon spacers, he is going to fabricate the !.5" drop and add a skid plate using the existing attachments in the frame and cross member.
  19. http://farm4.staticflickr.com/3774/9363253802_84aa181640_m.jpg http://farm6.staticflickr.com/5500/9360471795_bbd1a7e23c_m.jpg 2 pics, not sure if they will work?
  20. Ok now we have that settled, has anyone had any success moving the xj ax 15 cross member over to an mj? My 88 don't like it. Also I hate flicr, anyone got a user friendly photo shop?
  21. The mj has 2 extra brackets on the inside of the frame to accommodate 4 extra bolts. I found 2 plugged holes on these brackets and looks like I may get 2 bolts on each side, but not in the frame like the xj.
  22. My donor xj only had 4 bolts / 2 each side holding the crossmember
  23. II'm going to have a better look underneath hole were out by an inch, there are like you said 6 holes but I'm quite sure none of them lined up, I'll also get some pics together
  24. not flipped,will only bolt on 1 way to tranny, besides the exhaust hanger is the same on both, passenger side. The bolts are out an inch from factory frame holes.
  25. we are converting 88 mj BA-10 2wd to 4wd , donor 91 xj AX-15/231 TC. Both 4litre engines. Everything lined up until we got to the crossmember. It doesnt line up with factory frame bolt holes on my 88 mj? Any insight would be appreciated!
