Starter issue check ground on engine at dipstick where head block meet has to be clean and tight. Also try wiggling the shifter nss can do it too try cleaning the plug roughly same spot as said ground. Ground for fuel pump is by driver side tail light really i doubt its the issue recheck the fuel pump wiring inside the tank and the plug.
87 is renix. Above 91 at the least you'll need is intakemani complete exhaust all the way to cat, thortle pedal with cable, and adapt the throttle position cable.
Turn wheels straight, i bet steering wheel is off, adjust till your wheels are straight and steering wheel is straight.
Id measure mine but i need to adjust mine yet and lift is going in soon so mine will be different than urs.
Bleed down is normal usually around 12 psi. Test fuel pressure with it running driving stick gauge on windshield then go from there. But I would start looking at other areas. Clogged cat? Electrical issue? Sensor?
Its a dana 35 for now ford8.8. In a few months. U are correct about setup.
Yea i hear ya on lift those are 235/75/15 going to either 33 or 32. I figure the money i saved on rear lift will help with tires
