Geonovast
  1. Well, it's pretty obvious the article was written by someone who didn't do any research. Is this an online article?
  2. Geonovast
    4wd hub studs
    You might want to specify which U-joint size you need. Also... 3?
  3. The ignition switch is at the base of the column. You don't need to take the column apart at all to get to it.
  4. Remember that the individual gauges are swappable, so if you can find just a replacement tach, you won't need to buy a whole new cluster.
  5. :no:
  6. Yes, but 2wd and 4wd cables are not the same length. 2.5 cables may also be different lengths, and there's also the differences between cruise and non-cruise cables. You're looking at 4-8 different cables, so try to get as close as you can when you get a replacement.
  7. AFAIK, the only difference between 87-90 harnesses is that the 87 might not have a ballast resistor. Also, again not 100% on this, but I think that the XJ and the MJ used different firewall plugs to connect to the dash harness.
  8. Sounds like your clutch is beginning to slip.
  9. You would need to do an entire HO conversion.
  10. I love you. I need to remember this.
  11. That stupid light in my first XJ used to come on all the time in 5th cruising at 70. First thing I did with all my manual Jeeps was pop the cluster and take that light out.
  12. I'm in Springfield, Missouri. :dunno:
  13. A radiator "only leaking a little" can turn into a big problem pretty quick.
  14. I think he had his rebuilt... right?
  15. Thank you! My brother and I used to play it all the friggin time. We never got past the part where you're falling down the giant hole. We always ended up accidentally killing one another. I still have a working NES, and a working copy of Battletoads. I should fire it up again...
  16. http://www.coolrom.com has much, much more.
  17. There are no differences between XJ and MJ crossmembers. The BA 10/5 and AX-15 do use different crossmembers, however.
  18. Ok, gotta ask.. What gearing is in your "4x4 axles"?
  19. Like learn how to ^&$)ing spell, especially when the name of what you're selling is BADGED ON THE SIDE OF THE VEHICLE. Also, picture or I don't care. Most things can be sold by just a description, but if you're selling a vehicle, put up a freaking picture.
  20. I've done pretty much the exact same thing, although I wasn't doing 20 over.
  21. Not just a standard USB cable?
  22. At least it wasn't the bed. :dunno:
  23. Or just get under it and look. viewtopic.php?f=9&t=11699
  24. 4.10s lasted as long as the 2.5 did in XJs, which I believe was up into the late 2000.
