My truck's just a 4 banger 4 speed right now, but I'm planning and dropping 4.6 and AX-15 into it soon, only thing holding me back right now is the money.
Right now, I have a 92 4.0 from a scrapped XJ that still runs but it would be a good idea to rebuild it before going into a vehicle, so I might as well do the stroker. There was an AX-15 with it, but my brother accidently sold it (long story)
I also have the complete engine bay wiring harness and Computer from that truck
I have found sources for almost everything I need; Gasket set, Rockers, Pivots, Push Rods, Lifters, Cam (aftermarket from Summit.com Crane# CRN-753905), Cam Bearings, Timing Set, Main Bearings, Rod Bearings, Connecting Rods, Pistons, Rings, Dist Cap and Rotor, Oil Pump and Strainer, and Headers.
Haven't gotten ahold of a 258 crank yet, or any machining estimates. Otherwise internally all I think I need to find yet is valve springs.
I'm sure a few out you guys out there have done this build, is there anything I need to know about it? i.e. I know the snout on the 258 crank will need to be machined down.
Can I use the injectors from the XJ's manifold?
With needing the crank machined will I need oversized main bearings?
Going from the 4 to 6 cylinder, will I need to worry about any wiring other than the injector harness?
What color should I paint the motor?
Where can I get a good price on an AX-15?
Can I put the T-case from that's attached to the BA 10/5 from my 88 XJ onto the AX-15?
Thanks for any help!
