Location
LA CA
mj Mike's Achievements
Comanche Aficionado (4/11)
Well I always wanted to build it like a jeepspeed 3700 car. To get to that point I had to reinforce the chasis frame rails and fabricate a cage. Sent from my iPhone using Tapatalk
I have been doing a lot of testing in the last 8 years and just enjoying having a sweet Comanche with 4x4
Thanks 🍻 for the warm welcome back. the Comanche continues evolving. Frame stiffener & cage. cage is not yet complete. It need to be tied in at the frame & the rear end is incomplete until I pull the bad.
:idea: and for you brakes. check the wire connecter under the dash @ the brake peddle
top is hazard light relay bottom is blinker relay
replace the flasher relay on the fuse box :thumbsup:
Vaccuum line for a 1990 jeep Comanche
mj Mike replied to codymanche's topic in MJ Tech: Modification and Repairs
Rock Auto Part numbers. for the Rear Part # 46004 for the Front Part # 46003 -
The back half is the one from the Air Box. Part# 7151366 The front half that connects to the Valve Cover is part# 7151367
